20 Most Recent
Sony VAIO A260 Notebook Questions & Answers
Lan shutdown
take a look at this site for further help.
http://www.notebook-driver.com/category/sony-vaio/
AndystUK
Vaio wireless lan switch repeatedly restarts windows
Thats sounds like the wrong drivers for the network card. Some models can have different models or brands of cards so you can get the wrong one in there. You should be able to boot up in safe mode (F8) and then go under control panel - system- hardware manager-network adapters. Find the card that is causing the problems highlight and delete it. Then reboot. This takes the card out of the system and it will be detected as a new hardware next startup. Then try another driver.
You might want to go to the Sony website and check under support to see what other drivers you can get to try for your model. There might be 2-3 to try. Usually the oem disks are right but the replacements don't always get things right.
If this were hardware you shouldn't get the bluescreen of death (BSOD). That usually means software or drivers.
Touch pad not working
Only easy solution is to use a usb mouse instead :(
Touchpad can be replaced but its part of the actual casing so would be expensive to replace. :(
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
Lost video on svt131a11l
Try to:Open Computer by clicking the Start button and then clicking Computer.Navigate to the folder or drive that used to contain the video file, right click it and then click Restore previous versions. https://8ballpool.onl/ https://googlehangouts.ooo/ https://omegle.onl/
9/30/2018 12:52:58 AM •
Sony VAIO...
Answered
on Sep 30, 2018
System has slowed down and freezes regularly. it
A lot of anti viruses cant find or get rid of pups, which are potentially unwanted programs that sneak onto your computer, go to mybleepingcomputer.com and download and run adwcleaner, its free and gets the boogy men out.
1/22/2018 2:02:26 AM •
Sony VAIO...
Answered
on Jan 22, 2018
