20 Most Recent HP Pavilion N5415 Notebook Questions & Answers
How to remove the cmos battery?
Usually the CMOS is under panels under lappy,, there are removable panels usually with 1 or 2 screws. Normally one doesn't have to take it all apart.
1/27/2010 6:15:31 AM • HP Pavilion... • Answered on Jan 27, 2010
I re-imaged the unit & it says the network
1. Try different cable if possible.
2. Check the network port of the laptop. Make sure the pins are in tact and there is no dust/dirt or anything blocking the port.
3. Verify the other end as well. Check the hub/modem/switch or whatever you are plugging into. Make sure it's securely plugged in.
4. If plugging into a router, make sure you aren't plugged into the Uplink or Modem port. If it's a simple 4 port hub, avoid plugging into the uplink port as well.
5. If you have a cable modem that plugs into a router then into your computer, test by powering everything down. Plug the laptop directly into modem's ethernet port. Turn power on to modem. Turn power on to laptop. Check your network light and test internet. If it works there's something wrong with router. If it doesn't, look to the cable for issues.
6. Lastly, if none of those steps worked, remove the ethernet driver and reboot laptop. Let Windows detect the ethernet card, then re-install the driver choosing to overwrite the existing. Know that Windows will tell you you're device is ok just because a driver loaded successfully. It doesn't always know if the driver is the correct one.
9/29/2009 1:38:57 PM • HP Pavilion... • Answered on Sep 29, 2009
Wet pavilion
Theres most likely water inside the laptop, you should take it apart and dry it well.
Then purchase a charger if you don't have one since you can't use it without one.
4/26/2009 11:31:14 PM • HP Pavilion... • Answered on Apr 26, 2009
Removing the cover to get to the hard drive on a pavilion n5415
flip your computer over, use a screw driver to get the top off
suggestion- wear surgical gloves--best not to touch the hard drive
on a laptop, you sometimes cant expand the hd because the box is too small
4/24/2009 8:00:39 PM • HP Pavilion... • Answered on Apr 24, 2009
I have email error 99999
delete and reinstall your email software.
6/25/2023 8:52:09 PM • HP Pavilion... • Answered on Jun 25, 2023
Removing virtual drive
It depends what program you used to add it in the first place. Open the software and look for settings, or just uninstall it.
11/30/2022 7:10:30 AM • HP Pavilion... • Answered on Nov 30, 2022
How do i get mywindows keyboard to work
desktop or laptop. ? external Keyboard or internal
6/9/2022 10:54:32 AM • HP Pavilion... • Answered on Jun 09, 2022
What causes a red screen when starting up?
no pc told, Pavilion means zerothat name is is used on desktops and laptops for agesthe HP has diagnostics so run those. HP.com tells how.not told desktop or laptops. just 1 word."Screen"first Pavilion was 1995
6/2/2022 6:19:00 PM • HP Pavilion... • Answered on Jun 02, 2022
Hp pavilion entertainment pc 17 sd ms pro mmc xd
HP.COM << go there. And ask a real question ,you did not.
5/25/2022 11:36:13 AM • HP Pavilion... • Answered on May 25, 2022
What does a HP laptop notebook with model number A6Y530A look like
learn to google mate. this is no secret,gee millions sold. A6Y530A the partsurfer shows true model, and fails this is the only post here ever asking for reverse code lookups on models fake, and is not easy in vast cases I guess you have no such PC, (look like) so why ask this>? what prompted this quest>? not told why not ask seller for photos of it if this is a pre sales question , is it>? google and bing and HP all show that model # is BOGUS so go back to your sell and ask the we can not guess PCs ever. HP product ID# is best on the service tag for SURE. where did you see this number, not told. or that number is some 20+ year old COMPAQ PC ,lost in the sands of time, and no google hits. you posted to HP forum, (not real) Hp.com is real
5/2/2022 12:59:02 PM • HP Pavilion... • Answered on May 02, 2022
Hp pavilion g series manual
what does not working mean (KBD) dead, or 1 key bad or row. what? symptoms matter most, for sure in a LAPTOP IS IT the word Pavilion is on laptops and desktop, dig? G mean zero , the service tag does not just say "G" sorry. easy peasy lemon squeezy HP.com complex URL no? go there tell them your model # or better the service tag code ! . then magically HP puts you on YOUR service support page and all manuals and all driver before your eyes. amazing no? NO told at all or of a laptop or desktop or what./? you posted ANON so I can't just read other posts by you to learn what PC this is , no I can not. there are over 100 PC called G series, and vast years. some PCs by them G1 to 7 are generations, like HP Pavilion g6-1029tx Notebook. if you can find the service tag the product ID # is what matters most this code includes (real model, version , options and country sold) see this, older PCs by them had this. see that , all matters but do not post SN/ or service codes in public. mine: procuct code (nnnnnnABA#) https://www.pcdied.com/TAG-jive/tag-elite8540w.JPG I will guess it is 17" laptop, here is the mess just that 1 sized once you see this you know that G series means not MUCH> https://search.brave.com/images?q=hp+G+series++pavilion++17%22+G&source=web
5/2/2022 12:17:49 PM • HP Pavilion... • Answered on May 02, 2022
The airplane mode button is stuck on orange although my computer say's airplane mode off
old PCs do that, for many reasons. but no PC told at all just HP. 40 years of PCs ,10000 + models nobody can guess ever. but I do have the answer, in pure generic form. did you buy the PC like that used and bad Wifi. ?
  1. the wifi card is missing, as was super common 10+ years ago.
  2. someone put in the wrong card, not from HP list
  3. HP blacklists (bios blocks) none HP cards (wifi)
  4. the card needs a driver to work if not it is dead or 1/2 dead.
  5. the PC needs 1 more driver to make the wifi buttons all work , all buttons related, if not they are dead or act odd.
  6. The OS is infected, no OS told at all, not one clue nor if upgraded the OS, and not vast drivers are wrong or missing, (classic)
Im sure this this is not the free w10 upgrade, if it was that too kills drivers dead, for sure HP told you this unstated PC will not run W10 and has zero support from HP, on w10 AS YOUR SUPPORT PAGE WILL DISCLOSE TO YOU AT HP.COM
5/2/2022 11:38:43 AM • HP Pavilion... • Answered on May 02, 2022
Fix pdf handler
today there are many PDF , Viewers not juts Adobe ! google finds them like this. https://www.google.com/search?q=pdf%20viewers
5/2/2022 11:25:45 AM • HP Pavilion... • Answered on May 02, 2022
How reinstall bios on a HP dv9000
bad news now your bricked it just like miillions did google bios update bricked my PC and cry. why are you here and not at HP.com only they can recover bios. they changed the rules now 10 time. so only they know this, and are pain to deal with. UEFI is the enemy here, new rule and regressive as can be. in fact all new PCs can not be regressed, and some old now they even delete the 20 version of bios there, to force that. not saying they did that to your PC, but keep that in your head on all HP PC. the last bios upgrade stated, no going back. the Cntrl_+B might work , the flashback bios trick\ in your manual if you read it.
5/1/2022 4:52:54 PM • HP Pavilion... • Answered on May 01, 2022
How do i remove the tuvaro virus ?
nobody can we erase all and reload the OS fresh. did not say you can not try but that 99 out 100 will fail.
5/1/2022 4:42:46 PM • HP Pavilion... • Answered on May 01, 2022
How do i diagnose/test and repair my laptop
100% dead black screen no text or HP SPLASH screen now. The problem is hardware where we buy hardware for free, less than at deity level or a thief. you tell me.... no PC told at all not one tiny clue of 1000s of HP models for 4decades are we to guess models and lie to you? now the GENERIC answer USA PCs only sorry I do not do others. fans dead? no beeps> codes no Caps lock key blink codes. no text errors.? 1: does PC run BIOS pages if huge now shorted old relic battery is removed ,yes bingo 1. 2: is the RTC coin cell dead, ,Bingo 2. a $1 uSD ,USA cost. here. 3: the pre 2010 all have bad CCFL lamps; do this flash light test? https://www.pcdied.com/monitors_and_screens/flash-light-trick.html#flashlighttest if yes, that is a $50 to $100 USD parts repair , labor more. repairs are serial process, as fixing one thing bad ,uncovers the next this is how mans machines work just like that. NO PC told, NO PC told,NO PC told,NO PC told,NO PC told,NO PC told,NO PC told, all I can do is BEG,
5/1/2022 4:34:40 PM • HP Pavilion... • Answered on May 01, 2022
Where can I find a user manul for my HP Pavilion 15t touch
hp.com go there tell what PC it is (above is wrong, you truncated it) only full model names and number all work. or use your service tag number.
5/1/2022 3:23:49 PM • HP Pavilion... • Answered on May 01, 2022
If I am in a Dead Zone for Wireless Computers could my internet blue light be on and still no connection?
DEAD ZONE IS THAT A PC GAME OR just means in a quandary. yes, is he answer. wifi zone dead, move closer to the router. bingo. WIFI YOU MEAN, "SPECIFICALLY" not Bluetooth or WWLAN 5G. sure. BLUE, I GUESS YOU MEAN YOUR CABLE MODEM IS BLUE LED GLOWING?, well , there are 100s of routers and modems now, even mixed. to 1. yes if the modem LED show connection is good that means it is. but does not mean he PC is ok , nor the router nor the DNS setting best is, call your ISP if all PCs fails and home if only one fails on wifi the say so and we fix just that one failing PC. or reset the router and modem if all fail.
  1. first do the modem , pull the AC power pack from modem
  2. replace in a minute or 2,
  3. the wait for modem to show all good LED CONDTIONS.
  4. THEN DO THE SAME ON THE ROUTER.
  5. DO NOT PUSH ANY RESET BUTTONS OR BAD HAPPENS.
The ISP will tell 1-5 and does to every caller. endlessly ISP means internet service provider,
5/1/2022 12:13:54 PM • HP Pavilion... • Answered on May 01, 2022
HP Pavilion N5415 Notebook Logo
8 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
wet pavilion
  • Computers & Internet
