20 Most Recent
HP Business Inkjet 1000 Printer Questions & Answers
I have hp deskjet 1000
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken.
Thank you for using Fixya
Hp Business inkjet 1000
wont stop
You need to view the print que and cancel all prints.
Do the following:
1.) Navigate to windows control panel and double click Printers and Faxes.
2.) Now double click on your Hp Business inkjet 1000 Printer it should come up with the que.
3.) Click Printer and then click Cancel all documents. That is the Printer tab on the top left of the box.
That should cancel the documents in the print que and you printer should be able to rest now.
Thanks
Till next time!
damnor01
Lights on front panel are
Hello.
The lights are indicating that the Cyan ink cartridge is low or a non-HP ink cartridge is installed.
Hope this helps.
Shared printing problem
Go to Control panel open printers and faxes delete the existing printer, re install it by clicking the add printer, browse the path to your boss machine, when you find the printer auto install it.
Wont print copys
Try performing a scan. Probably the scanner or the scanner flat cable is damaged.
