20 Most Recent HP cp1700 Color Inkjet Printer Questions & Answers
I don't own one of these or I'd be glad to send you a photo. Try going to a retail office supply store where they sell this printer and take the photo.
HP cp1700 Color... | Answered on Apr 05, 2016
Your printhead is probably clogged. It's a replaceable (expensive) part. Try cleaning it first. Do a google search on how to clean a clogged printhead for your printer model. In most cases there are excellent YouTube videos that will guide you better than any written description.
This is problem many of hp cp1700 printers. LCD display have manufacter issuse. After some time degrage material joins LCD with controler. You can partial fix this issue, but you must take to parts front panel and repair cable contact on both side of plastic flat wire
(one side plastic flat wire and LCD, two side plastic flat and LCD controler board ). Repair must be done with stress dull tip and hot temperature, may use tinfioil and soldering iron.
OR you can bay new part panel board with lcd aproximaly 150$.
OR you do not repair printer and use pc program that view display info form printer display on pc monitor. On Linux I use HPLIP Toolbox.
HP cp1700 Color... | Answered on Dec 25, 2014
not possible legally.
new info chip required for cartridge.
3rd party inks WILL cost more ( if you include the damage they cause) in the long run - known FACT.
strongly recommend you revert back to HP inks as soon as possible.
HP cp1700 Color... | Answered on Mar 11, 2014
You can try using it and hope that it will work. If it doesn't then you will have to buy a new one. Don't worry nothing bad will happen to your printer.
HP cp1700 Color... | Answered on Dec 01, 2013
I have the identical problem with an HP Business Inkjet 1100.
Once cartridges were past date, the printer would no longer print from Windows XP. It would however work perfectly from Linux.
I did not find an ini file as mentioned in other posts, and I really did not want to open the printer as it worked fine in Linux.
The following fixed the problem:
1) Click on Start button, run
2) Type in regedit, enter
3) Navigate to HKLM/software/Hewlett-Packard/HP Printers/HPWH Toolbox/Common
4) In the right panel, right click on Ink, pick modify
5) Change 0100 to 0000
6) Save and reboot
HP cp1700 Color... | Answered on Jul 23, 2013
how to clean "pump stall" on cp1700hp
HP cp1700 Color... | Answered on Oct 28, 2012
Its the cable which attaches to the lcd display, you have to press on the contact areas where the cable attaches to the lcd glass and circuit board.
HP cp1700 Color... | Answered on Sep 03, 2012
Please check the cartridge page yield before procuring it. Check the cartridge part number last digit, if it is suffix with "A" it will only last 1400 page yield, if it is lasting with "AD" it will last up-to 2000 page yield. Also double check the toner cartridge is originally made by HP. No chance for logic fault.
HP cp1700 Color... | Answered on Feb 17, 2012
HP cp1700 Color Inkjet Printer Logo
81 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
InkJet HP
  • InkJet HP
Most Popular Question
reset carteridge
  • Office Equipment & Supplies
