20 Most Recent
AcerPower PC Desktop Questions & Answers
PC get shutdown automatically
It can happen in several cases. Like:1. If your processors cooling fan does not run properly or stops running , your processor gets over heated and will automatically shutdown to prevent damage of your motherboard. In this case check this first, If is runs but not seem so smooth, just clean it- dust can jam the cooling fan. 2.If your heat sink under the cooling fan is not perfectly fit on the processor, cooling fan will not able to cool it and will result your machine shutdown!3. In case of Bad power supply, it can also happen. Check your power supply.4.If your machine have defected RAM or became defected, it may happen. In this case you may have blue screen with message before shutdown your machine.5. If you have operating system of Microsoft Windows, please check your hard drive for virus. Virus can shutdown machine with a common period of time! Damaged OS which occurs often in windows operating system also can force to shutdown machine.Please check which one is in your case. Please mention problem details like something unfamiliar for further query.
Bios settings
Normally when the acer logo shows up press F2 that should take you in the bios setting, shows up on lower left if key assignment number is different.
Where do I find my cvv2 code when Im filling out
CVV2 code would be the last 3 number on the back of the magnetic strip on VISA and MASTERCARD and the 4 numbers on the front on AMERICAN EXPRESS.
You could have a look at the below images to have more clarification :-
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
I have problem on my
Noise coming from the motherboard is likely a fan or something mechanical on the processor, I would guess.
Normally, motherboards make no sounds, except maybe a beep if there is a fatal error, but that's due to incompatible components plugged in to the motherboard, or burnt out components on the motherboard.
My cursor is stuck in the middle of my pc screen.
- Have you tried cleaning the optical lense on the bottom?
- Or unplugging it, restarting your computer, and then pluggin it back in?
- Have you went into your control panel/mouse (properties) then click on the "hardware tab" to do a "troubleshoot" or it's properties?
I have had several mouse(mice) go out on me. These are the steps I try first. Good Luck!
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
