20 Most Recent
Viore 42" 1080p Led42vf80 Lcd Led Hdtv Questions & Answers
Viore tv troubleshooting
if you get no menu then it might be the lighting control board.
its it bright white but no video then you likely have video board issue .
youll need help. working on the inside will put you eye out
42 inch viore smart tv works great but then just shuts off ?
it may be interference with other remote operated items within say 300 ft of this tv..like celphone signals..or some electrical issue creating an electromagnetic field strong enough to makle it work funny..check all electrical components for interference issues..
Viore power supply
It is not a power supply fault. Check the main digital processor board.
If you wish to get more details, check this site linked
below. Pull up older posts there. Check
the site with patience, as it has over 2380 posts now. All are related to electronic equipment
repair help. If you search the site in
Timeslide option, which can be selected from the drop down list at the top left
of the display window, it will be easy to locate the related post. You can also do a search by type in the
brand name to your device into its search box at the top right of display
window. http://electronicshelponline.blogspot.com/
I lose picture and sound on my Viore TV after 15-20 minutes although the light is still green. I have to turn tv off for about 10-15 minutes and then turn it on to get the picture back?
This issue with losing picture and sound on your Viore TV after a certain amount of time can be caused by several things:
Overheating: If the TV is overheating, it may cause the TV to shut off to prevent further damage. This is usually caused by poor ventilation or dust buildup in the TV. Clean the dust out of the TV and ensure that it has proper ventilation.
Power supply issues: If the power supply is not functioning correctly, it can cause the TV to turn off and then back on. You can try checking the voltage readings at the power supply to determine if this is the issue.
Bad capacitors: Capacitors can go bad over time and cause the TV to shut off and then back on. You can check the capacitors on the TV's power supply board for any signs of swelling, leaking, or rust.
Main board issues: The main board of the TV could be malfunctioning, causing the TV to shut off and then back on. If this is the case, you may need to replace the main board.
If you're not comfortable with the above steps, it's best to contact a qualified repair technician for assistance.
My viore tv Scans Ruf channels but won't scan digital channels. Power went off it lost all over the air channels
If your Viore TV is unable to scan digital channels after a power outage, there are a few things you can try to fix the issue:
- Check the TV's antenna connection: Make sure that the antenna is securely connected to the TV and that there is no damage to the cable.
- Rescan for channels: Go to the TV's menu and select "Auto Tuning" or "Channel Scan" to rescan for channels. Make sure to select the option for digital channels only.
- Check for software updates: Make sure that your TV has the latest software updates. Go to the TV's menu and check for any available updates.
- Perform a factory reset: A factory reset will restore your TV to its original settings. This can sometimes fix issues with channel scanning. Consult the manufacturer's manual for instruction.
- Check your TV's location: Make sure that your TV is in a location where it can receive a good signal. Try moving the TV or the antenna to a different location.
If none of these steps work, it's possible that the TV's tuner may be malfunctioning and may need to be repaired or replaced. Contact the manufacturer's customer service or a professional technician for further assistance.
Regenerate response
How do I get a signal on my Viore TV?
This is normally because you have touched the Source or Input button on the remote.
You can only get channels if there is something connected to it providing that signal;
Satellite Dish
Cable Box
Over Air Decoder and Aerial
Streaming Device
IPTV Unit
