20 Most Recent
M-Audio Luna Professional Microphone Questions & Answers
Microphone does not pick up any sound
Your mike requires a 48 volt phantom power supply which your preamp should be supplying. The most commonly overlooked problem is the cable. It must be wired for a balanced connection for phantom power to work correctly. 1=ground/shield, 2=hot(ve) and 3=cold(ve). None of these connections should be bridged to another and need to be kept separate to maintain a balanced connection. You will need to eliminate the preamp and mike cable as sources of the problem in order to determine if the mike is working correctly. You need to test this combination with a volt /ohm meter. If you don't know how to do this you should take it to the dealer you bought it from for testing or advice.
Bass Guitar Won't Register
The mics I have seen don't have a filter... but a lot of mixers do have a 100Hz mic input filter. Check the other equipment that you are using also.
Audio bx5a tweeter
Tweeter just may need to be replaced. Is all the sound coming only from the woofer?
Loud rattling noise
hey shawn, try lowering the volumne level & see how the speakers react. www.tiger direct.com has new computer speakers,all different prices & different quality levels. from the best to the cheapest computer speakers.they carry all computer parts. 2 tb hard drives, $89.00for usb2 & usb 3 ports.
My fast track pro keeps
Do you have a "circuit protection" light or sign?
If not, you most likely have a faulty power supply like so many others with newer electronics now days. It should be tested with voltmeter to see if power supply is putting out a constant voltage reading. If it isn't, it may have bad capacitors in the unit. Bad caps will cause tv not to power or stay on.
