20 Most Recent Sony Ericsson P910 Questions & Answers
manual
My phon doesn't power on & back light is
As you said me you need to contact you are nearest Sony Ericsson service center there they will fix you are problem as soon as possible it's a simple problem.You need to get solve this problem as soon as possible.They make take a few minutes to solve you are problem.Thanks for you are question happy to help.
6/17/2011 5:32:27 AM • Sony Ericsson... • Answered on Jun 17, 2011
0answers
0answers
Connection of p910 with PC through DCU-11 failed
hi sounds like you need more configuration to the connection look here in the manual for connecting to other devices: http://www.sonyericsson.com/downloads/P910a_UG_R2a_AE.pdf page 134 and 154 (cable) good luck
11/18/2008 7:57:36 AM • Sony Ericsson... • Answered on Nov 18, 2008
Cannot read simcard
Either just switch off mobile than on or reload software........
7/11/2008 6:43:44 AM • Sony Ericsson... • Answered on Jul 11, 2008
Xperia Play Battery Drain and screen malfunction during charge.
The charging base is loose you have to replace.
It will work.
10/9/2017 4:42:24 AM • Sony Ericsson... • Answered on Oct 09, 2017
Update_service_setup-2.9.4.19.exe
What is the question?
8/12/2017 5:06:04 AM • Computers &... • Answered on Aug 12, 2017
Manual sony esperia mini
go here for manual http://www-support-downloads.sonymobile.com/st15/userguide_AE_ST15_1252-0138.1.pdf
6/4/2014 9:20:25 PM • Sony Ericsson... • Answered on Jun 04, 2014
W595 circuit board digrams
Does it work with just the battery or just the power supply? May need a new battery as they do not last forever. It may also need a new powers supply. Test if it works for one but not the other as that is the key.
4/24/2014 6:28:00 PM • Sony Ericsson... • Answered on Apr 24, 2014
No power w595 sony ericson
Probably shorted the power supply, but may have only blown the fuse. If you have a manual find where that fuse is and replace it. If it is not the fuse, replace the power supply, and cord as it is not expensive and is worth a try. Unfortunately, you may have fried the mother board. Amazon sells one for less than 50 dollars and it is easy to replace if you follow the instructions. There is a chance you may fried the CPU which could be more expensive. The hard drive is not, but may have been damaged too. It's worth a try on all counts as Sony's are not cheap to reacquire and that accident is not covered by your warranty as something that happens under normal use.
4/24/2014 6:25:51 PM • Sony Ericsson... • Answered on Apr 24, 2014
I can't get on to the internet
check access point setting manually get access point setting of your operator
4/11/2014 2:43:40 PM • Sony Ericsson... • Answered on Apr 11, 2014
0answers
0answers
Unblock youtube
Hahahahah You've been BLOCKED by You Tube? (Or your parents?)
1/25/2014 11:39:32 AM • Sony Ericsson... • Answered on Jan 25, 2014
0answers
0answers
Sony Ericsson P910 Logo
13 questions posted
Top Sony Ericsson Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
August Brown
August Brown
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
P Sony Ericsson
  • P Sony Ericsson
Most Popular Question
connection p910 pc dcu 11 failed
  • Computers & Internet
