20 Most Recent
Brother MFC9840CDW AllInOne Laser Printer Questions & Answers
Brother MFC 9840 CDW. How can I connect to wi-Fi?
Full instructions from the Brother website
Set up your Brother machine on a wireless network.
2. Set up a Brother machine on a wireless network
To set up your Brother machine on a wireless network:
- Connect the power cord to your Brother machine and then connect it to an AC power outlet (electrical socket).
Turn your Brother machine on.
- > Click here to see how to reset the network settings.
- Press the Up or Down arrow key to select the following:
- Select Network or LAN. Press OK.
- Select WLAN. Press OK.
- Select Setup Wizard. Press OK.
- When WLAN Enable? or Network I/F switched to Wireless appears, enable the wireless network.
This will start the wireless setup wizard.
- The machine will search for your network and display a list of available Network Names (SSIDs).
When a list of SSIDs appears, press the Up or Down arrow keys to select the SSID you wrote down earlier.
- Press OK.
- Press the Up or Down arrow key to select one of the options below: If your network is configured for Authentication and Encryption you must match the settings used for your network.
Available authentication and encryption methods depend on your model.
- No Authentication or Encryption:
Select Open System, press OK then select None for Encryption Type? and press OK.
To apply the settings, select Yes.
- No Authentication with WEP Encryption:
Select Open System, press OK then use the Up or Down arrow key to select WEP for the Encryption Type? and press OK.
Select the appropriate key number and press OK.
Enter the WEP key (Network Key), then press OK to apply your settings.
- Authentication with WEP Encryption:
Select Shared Key and press OK.
- Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:
Select WPA/WPA2-PSK, press OK then use the Up or Down arrow key to select TKIP or AES for the Encryption Type? and press OK.
Enter the WPA/WPA2-PSK password (Network Key), then press OK to apply your settings.
- Authentication with LEAP:
Select LEAP, press OK.
Enter the user name and press OK.
Enter the password (Network Key), then press OK to apply your settings.
- Authentication with EAP-FAX/NONE, EAP-FAQT/MS-CHAPv2, EAP-FAXT/GTC (TKIP or AES Encryption):
Select EAP-FAST/NONE, EAP-FAST/MSCHAP(EAP-FAST/MS-SHAPv2) or EAP-FAST/GTC, press OK then use the Up or Down arrow key to select TKIP or AES for the Encryption Type? and press OK.
- The machine tries to connect to the wireless network you have selected.
- If your Brother machine connected successfully
The machine's LCD displays Connected.
- If the connection failed
The machine's LCD displays Connection Fail or Connection NG.
Make sure your access point is on, and verify your Network Settings collected in Step1.
Temporarily move your machine as close as possible to the access point or router. Try starting from Step 2-2 again.
- The machine will automatically acquire the correct TCP/IP address information from your access point/router if DHCP is enabled (DHCP is normally enabled as default for most access point routers).
Once the Brother machine is joined to the network and has a valid IP address, the wireless setup is complete.
Videos
https://www.google.com/search?q=Brother+MFC+9840+CDW.+How+can+I+connect+to+wi-Fi%3F
Networking Guide
https://download.brother.com/welcome/doc002260/mfc9840_usaukasa_net_a.pdf
12/15/2020 12:23:46 AM •
Brother...
Answered
on Dec 15, 2020
Rainbow Color Streaks down the printouts that get worse the more pages printed
This is caused mainly by leaving the Corona Wire sliders anywhere other than where the arrows on the slider meets the arrows on the Drum Units. This leaves solid lines of colour down the length of the page (one per colour with the slider in the wrong place) if it is leaving more than the single line on the page it is probably leaking cartridges.
These particular cartridges are known for their ability to leak badly (OEM and Remanufactured cartridges do it). The only option for a leaking cartridge is to replace it and clean out the machine with a lint free cloth preferably a 'Toner Grabber' cloth. If you nee one of the toner grabber cloths then talk to your local cartridge refilling place for one. If they refil toner cartridges there then they probably have them or can suggest a different option.
8/20/2014 3:31:44 AM •
Brother...
Answered
on Aug 20, 2014
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Cannot reset toner counter for Brother MFC-9140CDN printer
You can reset the toner cartridges via the printer's menu.
- if an error message appears on the LCD display, press the Cancel (X) button to show the main menu.
- Press the Fax button to make the numeric keypad visible. Then, locate and only locate the Asterisk (Star) button on the numeric keypad. It is important to remember its location as it will not be lit up later when needed.
- Press the Home button to return to the main menu.
- Open the front cover of the printer (to access cartridges).
- With the front cover open, press and hold the unlit Asterisk (Star) button for 5 seconds.
- The reset menu will now appear on the LCD display.
- Scroll through the menu to select a color and yield to reset.
- The LCD will read "Accepted" once the reset is complete.
http://www.zinetic.co.uk/brother_mfc_9140cdn_toner_refill_kit-news.aspx
Scan unable af
The scanner unit is faulty or the flat harness was not fitted properly to the main board.
How do I print envelopes on Brother MFC6490CW
Load the envelopes in like paper, tell the printer the size of these to set the paper size, then whatever you're using to print on the envelopes, set up the page size the same size as the envelopes. You should then be able to print on envelopes
How to remove printer head on brother mfc 495 cw
1. Unscrew these three 12.1mm screws holding the control panel in place.
2. Lift up the front panel from the device.
3. Before removing the unit, apply 2 or 3 pieces of tape to secure the top and bottom of the unit.
Visit my computer
Brother mfc490cw printer show offline and error
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
Brother MFC490cw
Right-click on the printer in the folder and uncheck the "Use Printer Offline" option to place your printer online and available.
