20 Most Recent
TP-LINK TL-WR941ND Wireless N Router - 300Mbps, 802.11n/g/b, 4 Port Questions & Answers
How do block facebook port
Try using the parental control tools on your router to block it. As FB uses https:// the connection is encrypted, The router cannot see the URL accessed. Don't block https:// in general as you will not be able to access sites that uses a secure connection, ie Amazon, your bank, etc
10/26/2013 6:33:30 PM •
TP-LINK...
Answered
on Oct 26, 2013
I have a new TP-Link WR941ND router My new Toshiba
Greetings - Most likely the router is setup with a certain security type, such as WEP or WPA of which there are several types each.
Your laptop and Ipad have to be setup for the same kind of security as the router then the security key will work.
If you setup the router you have to log back into the router settings and see what kind of security is setup and what the login password is. If you didn't setup the router the person who did has to tell you what the security settings on your devices should be.
Good Luck and Thank you for using Fix Ya.
Mikeywaf
4/10/2011 7:24:47 AM •
TP-LINK...
Answered
on Apr 10, 2011
How to configure TP Link router connected to Thomson TWG850-4 ?
have you got two dhcp servers running ?
turn off dhcp server in wireless router
and use the one in the Thomson TWG850-4 Residential Voice Gateway.
make sure ip address in wireless router is different to the Thomson TWG850-4 Residential Voice Gateway. make it one higher on last digit of ip address
make sure dhcp does not lease out this ip address.
9/10/2021 10:58:38 AM •
TP-LINK...
Answered
on Sep 10, 2021
Error code: 4801
Error code: 4801 "System can't satisfy the requested min upstream rate. Please input again."
10/24/2019 12:56:49 AM •
TP-LINK...
Answered
on Oct 24, 2019
How do I set up a TP-Link wi-fi extender?
Hello, indicate model of the TP-Link that you are commenting, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola, indica modelo del TP-Link que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
6/4/2019 12:55:55 AM •
TP-LINK...
Answered
on Jun 04, 2019
