20 Most Recent TP-LINK TPLink TLWA5210G 24GHz High Power Wireless Outdoor CPE IEEE 80211 bg Up to 50km Wireless Ra (TLWA5210G) Questions & Answers
From what I understand, your device enables you to connection to an open network on a long range distance. Impressive. This device looks like is it most effective with no objects (buildings, trees,ETC..) in the way. I wouldn't try to reset the device. adjustments must be made. Consider the remote network you are connecting to. The owner of that network may turn off the wifi signal also control a limited amount of IP addresses it assigns (devices). Personally, I like having my own network without having to rely on someone
else's control of there network. The admin of that network could even restrict certain sites to be viewed or used.
TP-LINK TPLink... | Answered on Sep 26, 2016
Locate your router. There should be a label which displays your default gateway. The Default gateway displays a number. It should show a number like
  • 192.168.0.1
  • 192.168.1.1
  • 10.0.0.1
Open your browser (Internet Explorer, Chrome, ETC..) Type the default gateway number into the search engine text box on top of the screen press enter or return (mac). The page should now show user name and password. Locate the router and locate the default credentials. For example. most routers requires the user name to be blank and the password is password. Routers very.
About obtaining an IP address. Routers are usually set to option the IP address automatically unless you manually set a static IP address which is not recommended.
try to face the antenna to a different direction until you got a good signal first.
TP-LINK TPLink... | Answered on Sep 24, 2016
Read this web page as DHCP is not set-up by default on this router.
FAQ ID 348 How to configure TL WA5110G TL WA5210G as repeater
TP-LINK TPLink... | Answered on Feb 12, 2015
http://www.tp-link.ae/Resources/document/TL-WA7510N_V1_User_Guide.pdf
TP-LINK TPLink... | Answered on Nov 26, 2014
you can reset by tow ways :
first from configure router page .
second , if you didnt remember old usr & pass , connect directely through ethernet ,, or reset AP
TP-LINK TPLink... | Answered on Feb 03, 2014
check SSID , if shown ,, the problem with electricity ,, if not shown ,, check antina , if not shown ,, reset AP ,, configure agian ,, if not shown ,, replace AP
you can reset AP by entering to its page configuration ,then go system tool , then reset .
wireless not flashing ,, may be some reasons :
1- if there is a signal and its SSID shown , i think problem with electricity led .
2- if there no signal and its SSID doesnt shown , check antina if putting successfully , if not check configuration ,, if not reset AP ,, if not replace it
ok , need to assign your computer a Static IP address within the same
range as the AP's IP address, ip address of AP is : 192.168.1.254
the ip address for pc such: 192.168.1.253, then open your browser and write the ip address of your AP then you will be inside it .
TP-LINK TPLink... | Answered on Feb 02, 2014
Powerline adapters will most likely need to be on the same phase of your electrical hook-up. Try another wall outlet.
TP-LINK TPLink... | Answered on Dec 15, 2013
If you know the current one, just login to the admin interface, find the 'SECURITY' section and reset it to whatever you want. If you do not know it, you will need to reset the router (usually a simple push-button on the bottom or back - press and hold for a few seconds) and then login using the default login/password for the router and start over.
TP-LINK TPLink... | Answered on Dec 08, 2013
Turn off the router.
Press and hold small reset button (usually with a pin or pen) for 1 minute.
While still holding the reset button, turn the router back on and keep holding reset button for 30 seconds.
This will completely reset your router. The username/password will be set to default. (Usually Admin/Admin)
TP-LINK TPLink... | Answered on Sep 11, 2013
what is your problem ??
TP-LINK TPLink... | Answered on May 23, 2013
TP-LINK TPLink TLWA5210G 24GHz High Power Wireless Outdoor CPE IEEE 80211 bg Up to 50km Wireless Ra (TLWA5210G) Logo
Popular Tags
62 questions posted
Top TP-LINK Computers & Internet Experts
Lawrence Oravetz
Vernon Taylor
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • TP-LINK Computers & Internet
Most Popular Question
recently purchase tp
  • Computers & Internet
