20 Most Recent
Sony KV-32FX20U 32" TV Questions & Answers
No audio 14 inches tv
Check its speaker/s. Check whether the audio is muted. If all are found OK, check and replace the damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Viewing it in "
Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
My Toshiba 32ZP48 tv screen is pink and blue,
Absence of green is the fault. Check the video output section circuit for any loose solder terminals. This card can be located at the neck of the CRT, will directly plugged on to it. Check it. If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Sony KV-32FX20U picture has a colour cast
Check its video output card [a card directly plugged on to the back of the picture tube] for any loose solder terminals. Re-solder all the suspected solder terminals there, by applying a little more solder to each points. A bad solder point can cause this type of problem.
White lines
The problem here is with the vertical circuit. Most likely hte vertical IC is bad. Look for a small flat IC attached to a heat sink. It should have about 9 pins or so and be marked LA7837 or something similar. If you can solder, try resoldering the pins first. If that fails to resolve the problem, replace the IC. If you regain a picture but it appears distorted in some way, additional parts will be required. Update this with your results and we'll proceed from there.
Dan
Sony Trintron KV-32FX20U
This is a problem with the "AKB" circuit. There is a problem with the video signal. Are you comfortable changing parts inside the set? If so, please update this. I'll look up the specific parts for this model and post them.
Dan
Blank screen on startup on Sony KV-32FX20U
All Sony sets will stay blank until the circuit is ready to power the tube. If there is a problem detected inside the set, the tube will remain vlack and the standby light will blink. This blinking will repeat a count as follows: Blink count, pause for a second or two, repeat the blink count, etc. Some Sony sets will play for a while then flash off and on. This is usually an indication that the picture tube is starting to fail. In your case, you should see a blink code. If you can update this with the blink count, I can use that info plus the model number listed above to provide a possible cause and the parts required to repair the set.
Dan
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
