Question about Sony KV-32FX20U 32" TV
White lines My television has horizontal white lines through the middle of it and shuts off after a few minutes
Posted by joe salas on
  • Anonymous Feb 09, 2008
    white horizontel lines on my tv screen
  • Anonymous Dec 28, 2008
    My television has horizontal white lines through the middle of it wat would be the parts that normaly breakdown and replace it..thanks....
ABRsvcs
  • 4,234 Answers
The problem here is with the vertical circuit. Most likely hte vertical IC is bad. Look for a small flat IC attached to a heat sink. It should have about 9 pins or so and be marked LA7837 or something similar. If you can solder, try resoldering the pins first. If that fails to resolve the problem, replace the IC. If you regain a picture but it appears distorted in some way, additional parts will be required. Update this with your results and we'll proceed from there.
Dan
Posted on Mar 31, 2008
My Hitachi CT4533K Rear Projection TV only shows white lines.
Its a older set---look on front for the button for the convergence feature--if it got pressed the cross will appear--it is for aligning the basic convergence of the middle of the screen.
Jun 02, 2012 | Televison & Video
Black screen with white horizontal line in middle of screen. Turn tv off for about 20 minute and then tv okay
The solder connections at the vertical output integrated circuit are bad and losing contact as the part heats up. A few minutes with a soldering iron to repair the connections should fix that up.
Feb 28, 2010 | Televison & Video
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Intermittant white line with subsequent shut down
You have a vert ic problem very common tv problem.
POSSIABLE SOLUTIONS
1 COLD SOLDER JOINTS ON IC REPAIR COST IS 95.00
2 REPLACEMENT IC 120.00
CALL LOCAL TV SHOP AND ASK FOR PRICES ON A VERTICALE IC REPLACEMT. THANKS DOCTOR VIDEO
May 17, 2008 | Hitachi 36UX59B 36" TV
Nopicture
No vertical deflection. Vertical output IC, caps.
Nov 25, 2007 | Televison & Video
MITSUBISHI BIG SCREEN MODEL #VS55707
1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. IS the set shutting off or the hor. lines?
Aug 27, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Flicker-Blinking on picture
Too late now but I hope you had it serviced while it was still on parts warranty. With a couple of exceptions, service on those is by major pcb replacement.
Jun 04, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Televison & Video Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
