20 Most Recent JVC LT-32X776 Television Questions & Answers
0answers
What is this?
Be the first to answer 10/4/2017 11:57:02 PM • JVC LT-32X776... • Posted on Oct 04, 2017Be the first to answer
manual
JVC32X776 NO PICTURE
it is call an video module circuit you need to mention the part number of the module and the model of the tv good luck.
4/28/2007 1:44:42 AM • JVC LT-32X776... • Answered on Apr 28, 2007
My JVC 58in. Flat screen blinks?
The cable connections for your TV are not connected properly or are loose or the cables might have damage or the connection ports are broken.
12/6/2022 5:26:37 PM • JVC LT Televison... • Answered on Dec 06, 2022
2answers
The USB will not work for pausing live TV how can I fix this?
no info generic answer read owners manual or search online for one
5/14/2022 12:50:19 PM • JVC LT Televison... • Answered on May 14, 2022
JVC TV model,s avk14t3-1 has sound and no picture in audio-video mode
it needs service, that means using tools and meters and spare parts to find cause. dead screen black screened at all times.? even in HD TV antenna mode for HD TV? or just the remote CLICKER batteries dead. tell things that work and no not work , even LED actions. the maker has no books on this old TV https://jvcproducts.com/us/contact/support.html here they are ask them>? what rare TV. good luck fixing any RARE TV. moved you to TELEVISION.
3/24/2022 11:25:05 AM • JVC LT Televison... • Answered on Mar 24, 2022
TV is just over one month old - screen started getting darker and darker in pathes, now more than 60%, tried resetting all settings to default, tried all inputs (Video, HDMI, RF) all the same result -
Return it to your place of purchase and get something else anything else you wouldn't believe how many people are having Issues with the LT series get rid of it.
1/4/2018 12:22:16 PM • JVC LT Televison... • Answered on Jan 04, 2018
NO POWER LIGHT OR STANDBY LIGHT COMING ON
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge)
3/10/2016 7:13:11 PM • JVC LT Televison... • Answered on Mar 10, 2016
HOW DO I GET 4 DIGIT ACTIVATION CODE FOR IRISH TUNNING
Look for the manual of your Universal Remote and find the code assigned to your TV.. If no code, follor proper procedure for "no code available!"
8/25/2015 8:15:27 PM • JVC LT Televison... • Answered on Aug 25, 2015
A JVC LT42XM48 LCD Television set. Takes power has no picture or sound.
As a first step , if it is controlled via the remote, check that the remote batteries are good and that it is functioning ok. Does the tv show anything att all? If it does come on but shows nothing then it might be that the source selection is on the wrong kind of source, you can find on the remote whether this is so by going to the source menu which should probably be on digital. (I am assuming that you only have digital broadcasts where you are. If there is no picture whatsoever ubplug the set and check whether the internal fuse(s) are ok.)
6/8/2015 7:33:54 PM • JVC LT Televison... • Answered on Jun 08, 2015
Blue light keeps flashing and can't turn on tv
That blinking light is an indicator for possible service. If you TV has a consumable lamp, please check that before recommending service.
11/6/2014 4:46:59 PM • JVC LT Televison... • Answered on Nov 06, 2014
Jvc helpline
Contact the authorized dealer. http://electronicshelponline.blogspot.com/
9/6/2014 4:49:56 PM • JVC LT Televison... • Answered on Sep 06, 2014
0answers
0answers
JVC LT-32X776 Television Logo
5 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LT JVC
  • LT JVC
Most Popular Question
jvc32x776 no picture
  • Televison & Video
