Question about JVC Computers & Internet
The USB will not work for pausing live TV how can I fix this?
I have tries two USB devices which have both previously worked with this TV. The set is a JVC LT43C700. When I try there is a message on the screen that says the USB device is full but I can not find a way of deleting items from it.
Posted by David Wisdom on
  • Anonymous Dec 04, 2021
    its not a computer at all , it is a TELEVISION so please post to television?> not computers
    TELEVISION(TV)
    https://www.fixya.com/troubleshoot/jvc/t...
    no USB device i can not guess but here are some.
    my wild guess USB flash thumb drive,
    or 2nd guess USB HDD or USB SSD?
    or external, DVR (recorder) USB.
    if disks is uses and is full take it to any real computer (at TV is not a computer) and delete files.
    the TV may lie to you after all it has no real OS operating system , all it really knows is the DRIVE is failing.
    what is on the drive, USB, movies or just JPG photos? or music, TV can play many things what is on yours?
    what sizes disk is it,?
    does PC show it is full for corrupted.?
  • MaryMcCarthy
    MaryMcCarthy Dec 05, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
john h
    Top Expert:
  • JVC Master
  • 26,174 Answers
No info generic answer read owners manual or search online for one
Posted on Dec 05, 2021
My pause button does not work on live tv. It will pause on DVR shows.
I have seen freeze frame but I do not have a clue as how to stop a live tv show, that is saying everything stops on the show until you release it. Some TVs can buffer the show but then it is no longer live. That is what the DVR is for.
What do you do when your pause and rewind are not working on live tv programs?
Did they work before? For example, I bought my son a Samsung TV and the remote had rewind, pause etc. on the remote but they did not work. This is because the smart TV did not record the live image to allow this feature as it did not have any built in hard drive and I had to add a memory stick or hard drive into the USB port on the TV to allow the rewind, record and pause to work.
Lost Live TV after windows 7 Utimate system reinstall
is the usb connector and aerial all connected properly?
did the device driver install properly?
is ur computer PICKING UP ur Aerial and usb connector device?
is it classified as "Unknown" in device manager?
-- Uninstall ur TV Drivers, Reinstall ur TV Drivers, Restart ur computer, check all the use cables DONT use any usb adapters that would require more power for the usb and aerial. (i,e, use 1 single port not a 3 port adapter with the aerial attached) MAKE SURE its away from anything magnetic or electrical (fridges, tvs, radios)
Try again. if it worked before theres no reason why it shouldnt work now, think about what u have done differently -- how could it affect it now? how could that make a difference?
if nothing. its probably just ur drivers.
1helpful
The recorder if not recording and when watching previous recordings you cannot rewind or forward wind or turn off
for recording plz click this link may be it helps you
http://windows.microsoft.com/en-US/windows7/Record-TV-in-Windows-Media-Center
and for the change channel and pause live tv you change you remote set. may be it has some problem.
2answers
How do I play a movie on my Samsung blue ray without a remote
On fornt of the player you have the buttons for opreation.You can use these buttons to operate your DVD player with out remote.
I have attached a image for your BD-P1600 player so your reference
1.DISC TRAY :Opens to accept a disc.
2.DISPLAY :Displays the playing status, time, etc.
3.Remote Control Sensor :Detects signals from the remote control.
4.OPEN/CLOSE BUTTON :Opens and closes the disc tray.
5.SEARCH/SKIP BUTTONS :Goes to the next title/chapter/track or goes back to the previous title/chapter/track.
6.STOP BUTTON :Stops disc playback.
7.PLAY/PAUSE BUTTON: Plays a disc or pauses playback.
8.POWER BUTTON :Turns the Blu-ray Disc Player on and off.
9.USB HOST:A USB memory flash stick can be connected here and used as storage when connected
to BD-LIVE. It can also be used for firmware upgrades and MP3/JPEG playback.
Thanx
DVR refuses to rewind or pause live TV or record
ruukasu2005,
If you are still experiencing problems with your 625 receiver performing live DVR functions, try unplugging the receiver for about 10 seconds and plugging back in. This will cause the receiver to reboot and acquire satellite signal. After the picture returns, then try to pause. If it still doesn't work, then we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
XP crashed on my Dell latitude D600 laptop. I reloaded XP and all drivers. Everything works except it does not detect any device when plugged into the usb ports. They do light up. Utlities suggest that the...
I cant figure out a solution exactly as you have already tried things people have told you previously. but as far as i know dell should solve your problem for free instead of telling you to fix it. did you try contacting them and are you in your warrenty period?
Dvr doesent work
Hi djn Collinswhen your DVR is not allowing you to pause or rewind live TV you will need tounplug the receiver for 10 seconds and allow the receiver to power back up and acquirethe signal. Then you will want to try the functions again and make sure theyare working fully.
2answers
Web cam installation
hi
check the usb settings enabled in the bios or the cable inside the laptop.In some case the usb cable inside get fault and it will not detect the web cam.In normal case if you plug any usb device it will detect the usb device then the os will show new hardware found and will allow you to install the software for it,if it doesnt detect you cannot install the driver for it and in the yahoo messenger it give the message
Computers & Internet Logo
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Fernando Torres
Fernando Torres
Mehandi Husain ...
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
