20 Most Recent
Joytech Wireless Cordless PS2 Controller for Playstation 2 Questions & Answers
The controller is only connecting
It may be a matter of distance. Try using the controller at different distances from the receiver (both closer and farther) and see if it helps. If not, there may be interference from another wireless device. Look around for things that might be causing interference, like a nearby wireless router or a wireless internet modem.
If none of those things are present then your remote or receiver are actually broken.
I Have a problem with my joytech 8" digital lcd
Hi Juan,
Just bought one of these,
R138 is a 27 ohm (red purple black gold space brown), 1 watt, metal film, 1% tolerance resistor.
Hope thats all you need to get your display up and running!
Viper
Will 83069-U18 controller work on a PS2 please?
The Nyko Core Controller 83069 is a versatile controller that is compatible with both PCs and PlayStation 3 consoles1. However, there is no specific information available about its compatibility with a PlayStation 2 (PS2). It's always a good idea to check the product's user manual or contact the manufacturer for the most accurate information.
If you have a PS3 or a PC, you should be able to use this controller. Please note that compatibility can sometimes depend on the specific model of the console and the controller's firmware version
What does code 71 on a 2013 paccar 587 mean?
Its when the Shift attempts to pull out of gear, but the Gear Position Sensor indicates that the transmission was unable to disengage that gear. and detected a system failure, and unable to detect the cause.
Solitaire Customer Service Call 1-8O5-225-6690
We are 24 Hour Available Call Now
Well you really didn't loose them.
What happens is Hp puts in the software of a whole bunch of games where after time you have to go to their site and purchase their games.
Well there are other FREE sites to goto to find Solitaire, free cell, Spyder solitaire and such.
I also think that they meybe hidden files in Windows, but to find them you have to remove Hp games and then do a search
When the game turns on
Pokemon crystal is a Game boy color game, there for it will not run the original Game boy.
What are some good catering services?
I recomenr you Alchemiq, it is a quality caterers https://alchemiq.com/catering-nyc/. They offer gourmet appetizers, fancy food stations, upscale cocktail catering, and event design
Recommended System Requirements
Find out if you can run that game on your PC Learn about. System Requirements Lab
www.systemrequirementslab.com
you can find here the minimum and required system requirements for most of the games and the updates needed for you to download to make the games run on your system.
Update profile
Clear your question, because which types of profile update. Then i better answer given.
Thanks.
Well i got the new
Unfortunately, your Logitech controller uses the DirectInput control standard, and Deathly Hollows Part 1 will only work with the new XInput standard introduced in Windows 7. The only Xinput controller so far is a 360 controller hooked into the PC. There are also some software emulation solutions, but those can be a bit tricky and buggy to use. For the best experience, I'd recommend purchasing a 360 pad and the corresponding wireless sensor.
