20 Most Recent
Naxa Electronics NX984 Professional Microphone Questions & Answers
Installation
First you must determine if the mic's output from the receiver is low or high impedence. Tip: high imp. is usually a 1/4" jack , low imp. is a 3 pin XLR Conector. It also depends on your amplifier input jacks.But really you should connect the mic to a mixing console and then connect the console to the amp.But you could connect a high imp. mic via a 1/4" to 1/4",cable into the 1/4" jack on your guitar amp.
Staying in range
Just bought a the naxa NX-984 on http://www.jujudeals.com and I was having issues with the microphones receiving crazy feedback from each other. I couldn't figure what was wrong so I contacting their support department and they told me to make sure the frequency settings were set correctly. I noticed I had overlapping frequencies and with the flip of a switch everything was working great again. Felt like I wasn't the only one out there so I am sharing this tip with the community.
Why does screen change colors?
it is probably set to scan or random colors in the settings menu see if you can get to the settings and set it to one color
When I plug the earphone
Hi, this is a very common problem, after you have pulled the ear phones in and out a few times the solder on the earphone socket becomes brittle and breaks making you lose the connection with the circuit board, now as you have ruled out it being an earphone fault then the only possible problem could be the solder.
now sometimes if you wiggle the earphone at the part that goes into the mp3 you can sometimes get the sound working again, but this dont always work so dont rely on this,
now the problem you have is that the cost of getting this part fixed would cost a lot more than buying a new mp4 player.
the cheapest place to try and get this fixed is a tv repair shop, tell them exactly what the problem is so they dont have to test it and see how much they will charge you to resolder the earphone socket back in place properly.
that would be the cheapest option and could possibly get it working again if they will do the work for you
im sorry their is no easy fix but without getting the earphone socket re-soldered it will just never work
let me know if you need further assistance ok
Screen shows loading, cannot load driver
hi,
some naxa driver softwares are have inherent problems in compatibility with a few OS.
try getting a new copy of the driver from the vendor(it'll be free of cost), it is the simplest solution possible.
cheers
I NEED HELP downloading songs
Open Windows Media Player, click the arrow underneath the Rip tab, and select Rip Options --> Format --> Change the format to mp3. Now re-rip the songs and resync them to the mp3 player. Voila!
-Tha Mp3 Doctor
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
