20 Most Recent
Pentax Optio 430 Digital Camera Questions & Answers
Pentax option 430 camera problem
Bassie - did you resolve this? My computer recognizes the camera just fine. I have photos on my card but when I try to download to my computer, I don't see any photos. I've emailed Pentax several times w/ no help to this problem. Do you have automatic MS updates set on your machine? What Virus protection do you have? I've run into problems w/ another program conflicting w/ virus protection software.
Will 5 year old cameras take a 16gb card
Hi. Your camera is too old to accept that big a card. The camera will let you know what size it will accept. Just keep putting larger sizes until it stops. Hope that helps.
Pentax Optio E20 will not turn on.
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
What battery do I use in the Pentax Optico WGII
The Pentax Optio WG-2 takes an OEM manufactured battery or one designed for it. Google "Pentax Optio WG-2 replacement battery" or do a Amazon.com search for the same and you'll get thousands of options where to buy.
Camera saying connection fail when trying to transfer photos to pc via usb cable
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa (
http://picasa.google.com ).
Can't import photos to Picassa
Buy a USB card reader take card from camera and use that to import pictures. Sadly I can't help without knowing full details of your equipment, camera, computer operating system, etc.
I have a Pentax Optio E40 and get the message that the built in memory is full. How can I see what is in that memory? Can I delete those pictures to clear the memory?
Yes you can play back the images and/or delete them from the internal memory from the camera. I strongly recommend an SD card in the future. The internal memory can hold a maximum of about 87 pictures at the lowest resolution (2 pictures at the highest resolution). It'll be easiest to view the current pictures without an SD card in place.
To view the pictures, press the playback button (above and to the left of the 4-way arrow buttons) on the back of the camera. Use the left/right buttons in that 4-way area to navigate through the pictures. (You'll start at the last photo.) If you want to start the camera in playback mode, just press and hold the playback button while you turn on the camera.
To delete the picture that you are looking at, press the green/trash button to the right of the Menu button. Then press the up/down arrows to reach Delete and click OK (in the center of the 4-way buttons). (See Page 100 (page 102) of the manual.)
If you press the green button twice, you'll get a prompt to Delete all. That is similarly navigated with the up/down arrows and then OK.
Ricoh owns the Pentax Optio Line and has the manuals here:
http://www.us.ricoh-imaging.com/support/download-details/356 . (You'll need Adobe Reader to access the program.) The user manual is the second link.
I hope this helps.
