20 Most Recent
Dell PowerEdge T110 II Questions & Answers
Luz naranja parpadeante?
That depends on what is flashing orange. Please be more specific, and please post in English. In general, flashing orange lights on Dell servers mean something is wrong. Installing and running Dell OpenManage System Manager will usually tell you exactly what is wrong.
Power is 2950 i912 sel full
Namrata_stha,
The I912 error is referring to the System Event Log is full of events and because of this is unable to log anymore. You must clear the log in order for the Server Management controller to log any more events. Now depending on the OS installed there are different ways to clear it. If Windows Server 2k8 you would use this command - wevtutil el ' foreach { wevtutil cl $_ }
Where with Server 2003 you can go tot he Event viewer and clear it.
Let me know if this helps.
STRIKE f1 ERROR
Please be more specific. You haven't actually asked a question. What are you trying to do? What happens that you aren't expecting?
Format disk
what is your server model? in most cases you can use the operating disc to format the server drives
Serial number CDB6HJ1
Go to start menu. click on 'control panel'. Select 'system and security". Then select 'system'. This should give you the info.
Dell Poweredge 2900 I912 SEL FULL
Best is to find a support or systems engineer on http://www.qual.ch if you are in Switzerland and for the UK you can find find a top Dell expert or systems specialist on http://qualifind.co.uk -- I just asked one (from Qualifind) and was informed you just need to install Openmanage and clear the logs from there, no need to down the server.
My Dell Poweredge 1550 won't connect to the
Is it in a 1, 3, 2 beep pattern (beep....beep, beep, beep........beep, beep)? If so, the memory is either not seated well or may be bad. Try reseating your memory. If it continues, try with one stick at a time just to see if it will boot up with a display.Thanks,--Brian
