Question about Dell PowerEdge Computers & Internet
Dell pe 2650 raid 1 is missing member
Raid 1 is missing member. I have replaced a failed drive with a new drive. will it rebuild itself?
5 Related Answers
JaxPlanet
Jax Planet
  • 923 Answers
SOURCE: Dell Poweredge 2650 - How do I disable RAC
If this is a security concern then there is nothing to be concerned about so long as you do not plug a network cable into the RAC.
Otherwise, if it is an add-in card just remove it.
If you can't remove it there should be a way of accessing it when the server starts up. You should be able to go into the configuration and disable its functions.
I hope this helps.
Posted on Jul 19, 2009
bhaughee
Bill Haughee
  • 17 Answers
SOURCE: server does not recognize new drive installed to
what controller (may want to boot controller bios to format drive)
Posted on Aug 02, 2009
dante777
C. Dante
  • 623 Answers
SOURCE: How do I replace a 73Gb disk in a RAID 5 config - DELL PE 4600
That depends on your configuration.
If the drive you want to change is installed in the peripheral bay, you have to turn the machine off before you can pull that drive out. Also: Hot-plug drive installation is not supported for systems without an integrated RAID controller or host adapter expansion card!
Look for more details on how to change a drive here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Mar 09, 2010
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: I have dell 4600 pe serveri want to install
The hard drive needs to be set as the first SCSI ID device boot device..
The hard drive needs to have the jumper set to SCSI ID 0, the CD and FDD can be set to SCSI ID 1 and SCSI ID 2. No SCSI devices can have the same SCSI ID number unless it is on a different SCS controller.
Posted on Jul 16, 2010
ded_ch
ded_ch
  • 12 Answers
SOURCE: Dell poweredge t110 Raid 5
In a RAID 5 config, you need at least 3 drives (you can have more however). A small part of every drive is then reserved for recovery data for the other drives. So two drives together hold all the data needed to restore a 3rd drive.
The Raid Controllers in the Dell Poweredge Servers are hot swappable. So you can just pull the faulty disk and then insert a new replacement drive in the same slot (Needs to be the same type and size or bigger. However, if the disk is bigger than the other 2, then only the size of the two other disks will be used on the new drive). The Raid controller will then see that there is a new disk and automatically start the recovery process. You will be able to see this when you open the Controller software. Once the recovery is done, the RAID 5 will be fully functional again.
While one of the disks is faulty or missing the two remaining disks will continue to work, but at the severely degraded performance. After the rebuild the performance will be back to the way it was before.
The rebuild can take more than an hour, depending on the disk sizes used.
There is also an option on some Controllers to select one drive as a "spare". Then you insert one more disk and set it as spare. It will not start working unless one of the other disks in the Raid fails. That's when it is used automatically as a replacement.
Posted on May 02, 2011
How do I rebuild broken RAID 1?
If Raid is broken then logical drive will fail & will result in data loss.
enter into Smart Array Controller bios by pressing F8 & Recreate Raid 1 by selecting two working drives.
Nov 19, 2015 | HEWLETT-PACKARD Hewlett Packard HP...
Drive replacement and rebuilding Raid 1 on a Dimension XPS Gen 2
Did you format the new drive? Formatted size must be the same or bigger than remaining drive.
Mar 07, 2014 | Dell Dimension Computers & Internet
Drive replacement and rebuil ding Raid 1 on a Dimension XPS Gen 2
Hmm,tricky, I think your best bet would be to save old drive and do a complete new programme install hopefully you have the discs, then once setup and running, connect old drive as a backup and transfer data you require, there may be a better way, this is what I would seriously consider.
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
How to transfer OS and data to newer Poweredge server
The new RAID controller should read the data from the drives and work without difficulty. You will need to transfer all drives at the same time. Be sure to put the drives in the same spot in the new server.
Here are the bad news parts:
1. Your data is at risk. Make sure you do a good backup before trying this.
2. It is far more likely that your performance problems come from disk access or memory than the actual processor. If this is the case, then you probably won't be helping yourself with the migration. If you haven't already done so, analyze what is causing your performance bottleneck to make sure you are going in the right direction.
Jun 11, 2009 | Dell PowerEdge 2600 Server
I have a working Dell Poweredge 2650 with 2 x Xeon 1.8Gig processors, 5 x 36GB hard disks, running Windows 2003 Server. I have recently purchased a newer Poweredge 2650 with the same configuration except...
You should be able to do this by moving the drives all at once ALL DRIVES MUST BE PLACED IN THE SAME SLOTS 0,1,2,3,4, do not mismatch else it will be a nightmare ............HOWEVER BACKUP your data up if you are going this route,on paper it might sound like a winner,however not all that glitters is gold.controllers though they might be the same have different firmware which allow them to do different things,so if you are going to this the os drive raid 0 or 1 must be two seperate is drives.once this done,how is your raid set up for the other drives once you have a good back up to restore if there is any complication,move the over in the same order,remember POWER DOWN BEFORE YOU ATTEMPT THIS .PS REBUILDING TAKES FOREVER.
GOOD LUCK
Jun 08, 2009 | Dell Refurbished PowerEdge 2650 Server
I'm having some trouble with a dell poweredge 2650 I bought off eBay.
You are not too clear, however I'll take a guess ..
1) Booting from CD ... older CD drives fitted to PE26xx range do not recognize Windows 2003 bootable install CD's .. the TS-L462C (a laptop drive) should be compatible with the PE 2650 (I know it works in my 2600)
2) Installing the Operating System onto the PERC SCSI Array drives .. a total pain .. with older OS (Windows 2000) you can use the 4 x floppy disk set to install and hit (F6 ? as I recall) to tell it to 'load a 3rd party driver' ... get the PERC drivers from the Dell site.
Alternative = toss the useless Tape Drive and install a set of SATA drives in the same space (a 3 drive Hot Swap caddy eclosure will fit = Icy Box or StarTech) .. you will need a PCI RAID card (such as Si3124) since the M'Bd has nothing but a combined floppy/TapeDrive IDE interfafce.
3) Finally, be aware that this is a SERVER level box .. spare parts & Dell 'official' upgrades are going to cost you an arm & a leg = and don't even ask what the special 'ECC parity' Memory sticks cost :-)
Jan 22, 2009 | Dell PowerEdge 2650 (PE2650BB) Server
RAID rebuild problem
Your NUMBER 1 ENEMY when doing multiple drives in a single case is HEAT!!!! Make 100% sure those drives are COOL!!! if not you will continue to have issues.
Dec 10, 2008 | Biostar P4M800-M7A Motherboard
Raid failure
Not a lot of details, but here is some basic information, assuming you have a Dell with Integrated RAID
Dimension 9150/9200 and XPS systems have RAID, depending on the model the exact troubleshooting differs. At boot, after the Dell screen, you should get the RAID status listing. RAID 0 will either be normal or failed. Raid 1 can be normal, degraded for failed.
If the RAID array was RAID 0 and one of the drives failed, then all data is lost and you'll have to create a new array then reinstall Windows and drivers
If the RAID array was RAID 1, then you may need to add the new drive to the Array, CNTL+I or CNTL+N at boot (Depending on the system model) add the new drive to the array and reboot. If the system still will not boot to Windows, then you may have a software error too with the OS.
If during troubleshooting, the array was broken in the RAID BIOS, then the array will need to be recreated and Windows/Drivers reinstalled.
Jun 11, 2008 | Dell Dimension 2350 PC Desktop
Open Questions:
Computers & Internet Logo
61 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
