Question about Dell PowerEdge Computers & Internet
I have a Dell PowerEdge 1300 server and for the life of me I can't locate a service manual showing where the CPU fan plugs in.
Posted by Dale Bryant on
David
    Sergeant:
  • 486 Answers
You can download the service manual from Dell`s website or either check some youtube tutorials if available.
Posted on Nov 04, 2013
5 Related Answers
Anonymous
SOURCE: Dell PowerEdge 840
Look in Bios setup for OS Install mode setting. If it is enabled, it restricts the RAM to 256MB. Change the setting to off and it will sense the total RAM
Posted on Dec 09, 2007
Anonymous
SOURCE: PowerEdge 2600 does not boot up ?
this server is a compleate wast of time trust me
Posted on Jan 18, 2008
Anonymous
  • 7 Answers
SOURCE: dell server poweredge 1800 frequently shutdown
is there an error message that appears? can you check error logs? I need more information to be able to help you. I would first try to blow dust out of the fans, as it may be over heating, another possibility is that there is software on the machine that is causing it to shut down.
Posted on Mar 17, 2008
Anonymous
  • 5 Answers
SOURCE: Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
Posted on Jun 07, 2009
Shawn DuRee
  • 356 Answers
SOURCE: No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
Posted on Jun 07, 2010
Replacing cpu fan
These are the Dell part numbers for the PowerEdge 1600 SC heatsink:
7R181 Heatsink Assembly (Includes heatsink and fan)
83MGJ Heatsink Clip (2 required)
Dell spare parts can be reached by phone at 1-800-357-3355
Mar 14, 2014 | Dell PowerEdge 1600...
Error poweredge system R510
Reset bios, test with a different power supply, ensure all cables connected securely to the CPU FAN header, and then conatact DELL support.
Oct 10, 2013 | Dell PE2800 Server
Power supply
Bad A) Video card B) Memory chip C) CPU or CPU fan
Jun 06, 2013 | Dell PowerEdge T100 Server
Dell poweredge 1800 has power light flashing but the computer won't turn on
I would start with reseating the RAM and disconnecting and reconnecting motherboard and system connections as there is a chance that something got rattled in shipping.
Where was it before it was in Panama? Maybe the power system is different and you might need a different power supply?
Aug 30, 2017 | Dell PowerEdge 1800 Server
Dell poweredge 2300 server have a contant beeping. i change the battery but still beep.
It probably is trying to tell you that it is overheating.
Check that the fan(s) on top of the CPU(s) is/are working.
Jul 30, 2010 | Dell PowerEdge 2300 Server
May 02, 2010 | Dell PowerEdge 1800 Server
DELL Poweredge 2600 Bios FREEZES After Cpu check and before SCSI Drives check HELP!!!!
The BIOS check can freeze for many reasons.
Can you tell me if this is an existing system that was working fine and then had this problem, or is this a new (or new to you) system?
Can you give more information on what is actually showing on the screen?
Nov 05, 2008 | Dell PowerEdge 2600 Server
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Open Questions:
Computers & Internet Logo
88 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
