20 Most Recent
2101L Keyless Entry Questions & Answers
When locking doors they unlock
What's the year, make and model of the vehicle? Are you saying that the door locks cycle...like the door is open when you try to lock it?
Both remotes failed to either
no reset button, sorry. If the starter is turning over, then it's more than likely not an alarm or keyless problem. if it was even connected, the starter kill feature is used to "cut" the starter wire from the ignition and the starter itself, and if you say it's turning over, that's where i get my answer for it not being the avital. of course there could be more to it, remote start added, and the type of car make a huge difference, could be a bypass module for bypassing a factory security system, so without any more info, that's all i can give you. hope this helps, dave
How can put my Avital 7345L remote starter on vibrate instead of chirping?
To put your Avital 7345L remote starter on vibrate instead of chirping, you will need to follow these steps:
- Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will put the remote starter into valet mode.
- Press and hold the "Lock" button on the remote starter until the parking lights flash twice. This will turn off the chirping feature.
- Press and hold the "Unlock" button on the remote starter until the parking lights flash twice. This will turn on the vibrate feature.
- Press and hold the "Valet" button on the remote starter until the parking lights flash twice. This will exit valet mode and save your settings.
- Test the remote starter to make sure that it is vibrating instead of chirping.
Note: If you have difficulty following these steps or if you have any other issues with your Avital 7345L remote starter, it is recommended that you consult the user manual or contact the manufacturer for assistance.
How can I get instrction book for reprograming avital remote starter for rpn 7111l
If you are looking to sync the remote key fob to the remote starter:
Remote programming 1. Turn key to the ON position 2. Within 5 seconds, press and release Valet button one time. 3. Within 5 seconds, press and hold the Valet button. The LED will flash one time and the horn honks to confirm entry into remote programming. 4. Press the button on the remote control. 5. The horn honks to confirm the remote has been programmed. 6. Release the Valet button, and turn the key to the Off position. 7. The horn sounds one long honk to confirm that remote programming has been exited. The programming routine exits if any of the following occurs: • The ignition is turned off • There is no activity for 30 seconds • The Valet button is pressed too many times
