20 Most Recent 4103LX Remote Start System with Two 4Button Remote Questions & Answers
2007 ford focus starts fine but shuts down after a couple minutes.
I got this free Pdf manua l from reliable-store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of all the times I fixed the chipper in these 4 years
1/25/2019 3:32:11 PM • 4103LX Remote... • Answered on Jan 25, 2019
I have a Dodge Caravan 2001 SE. Had the Avital
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U get free manuals
1/23/2019 9:58:26 AM • 4103LX Remote... • Answered on Jan 23, 2019
I recently had an avital 4103 remote start system
As an L1 ASE Master tech I ALWAYS advise against aftermarket alarm systems, however the problem you are experiencing is due to an action that is not being taken by the vehicles control modules. The installer should tie into the door control modules or find out why the body control module is recognizing the command for the locking/un-locking action, (hence the lighting response), but the doors are not taking appropriate action. I would have to look at live data in the vehicles control modules to see what modules are being commanded to do what. Take it back to the place where it was put in and tell them to fix it or refund it. Good luck!
12/22/2017 5:04:03 PM • 4103LX Remote... • Answered on Dec 22, 2017
My 4103lxl wont turn the car over or start but the find car workds
make sure the care doesnt have the check engine light on and if it does clear the codes and then it should work i had that problem
12/14/2017 1:17:56 PM • 4103LX Remote... • Answered on Dec 14, 2017
Remote starts but wont stay running. also wont start with key
Is the security light on or flashing? If you need further help, reach me via phone at https://www.6ya.com/expert/chris_b82b45c59bcf133d
12/8/2015 1:21:54 AM • 4103LX Remote... • Answered on Dec 08, 2015
I had an avital 4103 remote start professionaly installed and now then i go to put the key into the ignition it wont start. I have a 2001 chevy trailblazer. The dash flashes security and i leave my k
U are probly opening the door then hitting ur doorlock button then shutting the door. The factory system is being armed whwn u loxk the door. Try shutting the door without loxking it. See if ur factory alarm light came on. If that solves ye issue, u need to some minor rewire on ur alarm.
12/5/2015 5:46:37 AM • 4103LX Remote... • Answered on Dec 05, 2015
Installed on 1995 Jimmy. I'm told I need a relay to reverse the output polarity to work the door locks. Is this in addition to the existing door lock relay and if so where is it positioned
Hi, g.m uses 2 types of locks. Us oldtimers called them a 3wire or 5wire. The wires are on the switch. The diff is this. A three wire has relays built in. 5Wire uses the switches in series to make the connection. Its been my experience, to chk ur switches first.
12/5/2015 5:38:44 AM • 4103LX Remote... • Answered on Dec 05, 2015
Remote start only works when next to vehicle
Hi, i would guess ur remote batteries are needing replaced. Otherwise chk the ant. That is added on ur windsgield. It may have a connection issue.
12/5/2015 5:33:02 AM • 4103LX Remote... • Answered on Dec 05, 2015
2002 cavalier, ignition cylinder was changed for pass lock failure now remote start cranks but wont start. avital 4103L
Hi, ur problem is a simple one. U have a factory alarm-starter kill. The key and ecm have to comunicate. Ur alarm has a digital modual to make the ecm think its seeing the key when u remote start. Since u changed the "code"u have to reprogram your alarm interphase so it all comunicates the code.
12/5/2015 5:29:26 AM • 4103LX Remote... • Answered on Dec 05, 2015
2000 dodge durango remote starter
Go here to find wiring diagram for your truck - then you'll know where these wires are
7/30/2014 12:02:13 PM • 4103LX Remote... • Answered on Jul 30, 2014
Car rolls over with remote but will not start
Everything depends on missing information...like was it professionally installed?...and whats the year make and model of the vehicle. Here is some helpfull information. go to WWW.the12volt.com then click menu tab Choose vehicle wiring database Choose your vehicle Make sure all wiring was correct and any relays moduals resistor or any components required where used If everything is correct than its your alarm and its faulty
7/22/2014 5:50:27 AM • 4103LX Remote... • Answered on Jul 22, 2014
My remote starter shuts off as soon as it start
The ignition wire has not been wired in2 the system then - try checking all the wires r connected properly!!!! Good luck!!!
11/23/2013 3:59:57 AM • 4103LX Remote... • Answered on Nov 23, 2013
My fuse is good but still no park lights?? switch works great. any ideas helpful.
Do the parking lights work with the vehicle switch? Did the parking lights ever work with the remote starter/Keyless entry systems?
3/6/2013 4:39:10 PM • 4103LX Remote... • Answered on Mar 06, 2013
How do I activate the alarm on my Dodge
The 4103 is not an alarm. It's a remote starter with keyless entry! Do you want the horn to sound when locking and unlocking? First, make sure that the horn wire was connected. Press and hold the lock button on the remote. That should activate the panic/car finder. The horn will begin to sound. Press and release the lock button to turn it off.If the horn is connected and, you want said horn to sound when locking and unlocking, open door, turn ignition on then off, press and hold programming switch until the horn chirps once. Release programming button, press and release programming one time then, press and hold programming button. While holding the programming button press and release unlock button on remote. You should hear two chirps from the unit. Release programming button, turn ignition on to exit programming, Test system.
2/13/2013 4:52:36 PM • 4103LX Remote... • Answered on Feb 13, 2013
I need to know the steps ( opening driver door, turnig the key on n' off etc,etc. ) to activated the alarm 4103
The 4103 is not an alarm! It's a keyless entry and remote starter. So...what are you trying to do.
2/13/2013 4:44:51 PM • 4103LX Remote... • Answered on Feb 13, 2013
Windshield wipers will not turn off.
Wow...I would return to the place where the installation was done. It's possible that the installer either tapped into the wire or, left the wire exposed after testing it.
1/29/2013 11:01:04 PM • 4103LX Remote... • Answered on Jan 29, 2013
Tach and speedo quit working after remote start installed. My 04 yukon's speedo and tach will quit working. I can unplug battery for 5 minutes and will work for a few days. If I turn off vehical o
Well, if you connected the tach sense wire (violet/white) from the Avital, remove it and use either virtual tach or voltage. It sounds to me that whatever you have connected to the tachometer is sending a signal rather than sensing, causing the malfunction.
1/21/2013 6:56:58 AM • 4103LX Remote... • Answered on Jan 21, 2013
My lock/unlock remote works but my remote start does not work at all. Was professionally installed 2 years ago. No lights come on and nothing happens when i press the remote start.
Rip it out and do it manualy ,these viper and associated products use electrical components made in china and the specs fall well below the europeon standards of a phillips or a bosch unit ,old saying you get what you pay for.
11/13/2012 7:19:13 AM • 4103LX Remote... • Answered on Nov 13, 2012
No lights with avital
If your vehicle parking lights are working at the switch then, the inline parking light fuse(15 amp) of the Avital unit may be blown.
9/23/2012 2:17:05 AM • 4103LX Remote... • Answered on Sep 23, 2012
4103LX Remote Start System with Two 4Button Remote Logo
Popular Tags
37 questions posted
Top Avital Vehicle Parts & Accessories Experts
john h
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Avital Vehicle Parts & Accessories
Most Popular Question
installed 1995 jimmy told need relay
  • Vehicle Parts & Accessories
