Question about Avital Vehicle Parts & Accessories
Avital 5303l when remote starts activates, it sticks on starting sometimes and starter keep spinning off.
Jeff Harms
    Sergeant:
  • 264 Answers
When the car starts the remote start unit either recognizes because of voltage increase or begin rpm. Either the rpm sensor is not connected properly for the first, or your choice of defective remote start unit or alternator not charging.
Posted on Apr 23, 2019
5 Related Answers
ltfrc
Mike Schmidt
  • 227 Answers
SOURCE: engine cranks will start fine with key remote will not start it
Did it ever work as far as you Know? Some vehicles have a coded key and if the key is not in the ignition at the time the remote is activated it will not start. Some systems have a key hidden in the system and some have a bypass. It is hard for me to tell you which you have as not being the installer. You may have to contact Avital or go to thier web site for more detailed info.
Posted on Jan 28, 2009
ltfrc
Mike Schmidt
  • 227 Answers
SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
Anonymous
  • 95 Answers
SOURCE: I have a 1998 Chevy cavalier with Avital 3200
it sounds like its the bypass module. When it doesnt start the car goes into security mode and wont let it start for up to 15 minutes. I would check the bypass module to see if it still has power or has been reset, if its not something you can do, bring it to a local mobile electronics shop and they should be able to take care of it for ya.
Posted on Mar 03, 2009
Wilson Martinez
  • 171 Answers
SOURCE: AVITAL 4103 REMOTE STARTER STARTS BY ITS SELF
Check the alarm program it shoudl be programing to turns it On every 2 hours, or if you have a temperature sensor should be programed to turns it On when is too cold.
Posted on Jan 05, 2010
fordexpert
  • 5692 Answers
SOURCE: Ford f250 Truck 1987 460. Solenoid sticks once in
Most likely you need a new Ignition switch. The small "tickler" wires on your solenoid are staying on. You can disconnect the small wire from the Solenoid and then put a test light on it. Turn the Ignition to Start and see if the wire stays hot when you release the key.
Another problem you could have is the Starter has such a bad intermittent short in it, that it keeps the points welded together after the key is released from the Start position. You can get a starter Draw test done at some parts stores like Autozone or Oreillys to name a few, they do it free and on the truck.
Let me know the result please,
Posted on Oct 28, 2010
HOW TO OPEN TRUNK WITH AVITAL KEYLESS REMOTE
all depending if your trunk work with negative ,or positive pulse if it is positive you have to used a 5 pin relay and if its negative just connect it straight
May 17, 2015 | 5303L 2Way LCD Remote Start Security...
Avital 5303 would not work after changing the battery in the remote
be sure the polarity of a battery when you fix it in the remote unit
Feb 03, 2014 | 5303L Security/Remote Start System
After 12 minutes remote start run alarm goes off
How long do you want it to run? Thats normal go into setup if you want to change
Feb 03, 2014 | 5303L 2Way LCD Remote Start Security...
TPMS malfuntion for Kia Sportage 2008
It is caused from data interference by the bypass module. A different firmware will need to be used or a different bypass all together. If Frys recently installed it, then they should be responsible to fix under warranty.
Dec 29, 2013 | 5303L 2Way LCD Remote Start Security...
What do you need to install Avital - 2-Way LCD Remote Start with Security to a dodge magnum 2005
A security or transponder bypass.. there are a few different companies that make them.
Sep 25, 2013 | 5303L 2Way LCD Remote Start Security...
How do i reset my remote start car alarm avital 5303
i have a avital 7352l remote start my fob got smashed under the hood of my car still locks and unlocks car but went to use remote start and it tried to start car but it didnt then i got into my car and try to use my key and it didnt crank at all can anyone help me solve this problem?
Feb 21, 2011 | 5303L Security/Remote Start System
My car keeps on turning on by it's self and it does not have the timer set.
If your remote starter is activating "by itself" and there is no timed start setting initiated; the activation wire (white with blue stripe) is touching ground under the dash. Locate the command module of the Avital unit and isolate the white with blue wire by applying some tape to it.
Feb 04, 2011 | 477L Ask RXTX HHU Remote
Vehicle Parts & Accessories Logo
125 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
gludwick2
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
