20 Most Recent
JVC GY-HM100U High Definition Camcorder Questions & Answers
Hi there seems to be a problem with the iris to my
See if you can reset camera to factory defaults. If not then you have a serious issue with the camera electronics.
Think that puppy is ready for retirement since repair, if available, will cost a small fortune and not be worth it.
Hello guys, please only reply if you have a
When was the last time you white balanced your camera? I can't say for certain, but it sounds very similar to a problem I use to deal with all the time.
- set the ND filter according to the lighting
- set the WHT.BAL. switch to A or B
- locate a place with similar lighting conditions as the subject, place a white object near the center of the screen and zoom in to fill the screen with white
- press the auto white balance button
I got all of this from the
manual. starting on page 35. I hope this turns out to be it. Let me know how it works out!
I have a jvc GY-HM100U High Definition Camcorder
The gy-hm100 can record to sdhc media up to 32gb in each slot (total 64gb). For best performance you must use class 10 sd cards. Your camera may need updated firmware that enables class 10 support so check the JVC Pro website and follow the firmware instructions if you haven't done so already. Also, make sure your card is formatted and unlocked with plenty free space. 4 gb is not much at all and a card that size may not be of sufficient speed to operate correctly in the gy-hm100.
JVC HM100U auto exposure and image stabilization stopped working. Can control somewhat manually.
This is usually caused by a failed component in the power circuit within the camera. This will require disassembly and trouble-shooting to identify and replace the defective component and can usually be repaired fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jvc GY-HM100u will not focus. I removed the lens
The most likely cause for this is a zoom or focus lens out of place or impaired in some way. This will require disassembling camera to remove the lens block and then disassembling the lens block to repair. This can be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired by a qualified service technician.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Jvc AV70BT production mode
You can exit production mode by pressing the menu and reset button. Simply press and hold the MENU button first then press and hold the small reset button. Keep both buttons down until the radio powers off and back on. Do not let go of the buttons until the radio comes back on and off production mode.
You may also press the MENU and reset buttons repeatedly.
3/10/2024 6:13:37 PM •
JVC Video...
Answered
on Mar 10, 2024
JVC everio gz ms120 menu buttons no longer working
If you're experiencing issues with the menu buttons on your JVC Everio GZ-MS120 camcorder after adjusting the settings, there are a few troubleshooting steps you can try:
- Remove the power source: Disconnect the camcorder from any power source, including the battery and AC adapter. Leave it disconnected for a few minutes to ensure a complete power cycle.
- Reset the camcorder: While the power source is disconnected, press and hold the "Reset" button on the camcorder. The reset button is usually located in a small hole or recessed area and may require a small pin or paperclip to access. Hold the button for several seconds, then release it.
- Reconnect the power source: Reattach the battery or connect the AC adapter to the camcorder and turn it on. Check if the menu buttons are now responsive. If not, proceed to the next step.
- Connect to a computer: Use the USB cable to connect your camcorder to a computer. Once connected, some camcorders allow you to control and adjust settings through the computer's software or firmware update utilities. Try accessing the settings through the computer interface to adjust the display brightness or perform a factory reset.
- Contact JVC support: If the above steps don't resolve the issue, it's recommended to reach out to JVC's customer support for further assistance. They can provide specific guidance tailored to your camcorder model and help you troubleshoot the problem effectively.
Remember to provide as much detail as possible about the issue and the steps you've already taken when contacting support. This will help them provide accurate and efficient assistance.
6/18/2023 4:00:39 PM •
JVC Video...
Answered
on Jun 18, 2023
Play back on jvc video movie GR-A1E distorted
It is possible that the heads in your JVC video camera need cleaning, especially if the playback picture looks distorted and similar to a VHS tape played on a player with dirty heads. Dirty or worn-out heads can cause playback issues, including poor picture quality, distorted images, and tracking problems.
To clean the heads in your JVC video camera, you can try the following steps:
- Purchase a head cleaning cassette: You can find head cleaning cassettes online or in electronics stores. Make sure to get one that is compatible with your JVC video camera.
- Insert the cleaning cassette: Open the tape compartment on your JVC video camera and insert the head cleaning cassette. Close the tape compartment.
- Run the cleaning tape: Press the play button on your JVC video camera to run the cleaning tape. The cleaning tape will clean the video heads as it plays.
- Eject the cleaning tape: Once the cleaning tape has finished playing, eject it from your JVC video camera.
- Test your tapes: Try playing your tapes again to see if the picture quality has improved.
If cleaning the heads does not solve the problem, it is possible that there is a more serious issue with your JVC video camera.
3/18/2023 9:07:17 PM •
JVC Video...
Answered
on Mar 18, 2023
How to fix Jvc GR-D239E safemode 06?
Safemode 06 on JVC camcorders usually indicates a problem with the tape transport mechanism. It could be a mechanical issue or an electrical issue. It's possible that the black rubber you found inside the camera was a part of the tape transport mechanism that came loose or broke off. It's also possible that there is some debris or dirt stuck in the tape transport mechanism, preventing it from functioning properly.
One thing you can try is to clean the tape transport mechanism with a soft brush or compressed air. Be careful not to touch any of the delicate parts inside the camera. You can also try using a different tape to see if the problem is with the tape itself.
If cleaning the tape transport mechanism and using a different tape doesn't solve the problem, it may be necessary to take the camera to a professional for repair. They will be able to diagnose the issue more accurately and determine if any parts need to be replaced.
3/18/2023 8:18:17 PM •
JVC Video...
Answered
on Mar 18, 2023
