20 Most Recent Blue Coat Systems ProxySG SG210-5 Proxy Edition Security Appliance Questions & Answers
Problem with access multi layer sites going
are you able to provide more information regarding your problem?
8/18/2011 1:18:31 PM • Blue Coat... • Answered on Aug 18, 2011
I can ping the device but not explore in explorer
to connect to the management interface of the ProxySG the default address scheme is https://***.***.***.***:8082 (e.g. https://192.168.0.1:8082)
8/18/2011 1:17:00 PM • Blue Coat... • Answered on Aug 18, 2011
Forgot my applient sg210.4
there is a reset button located on the back of the appliance that can used to reset the appliance back to factory defaults
8/18/2011 1:14:35 PM • Blue Coat... • Answered on Aug 18, 2011
Changhong Ruba 58? 4K UHD Smart LED TV (U58H7i) showing horizontal purple and blue lines. How to fix please?
I believe you can troubleshoot by following steps below:
  1. Check the source: Make sure that the issue is not with the source device, such as a cable box or gaming console. Try connecting a different source device to the TV to see if the issue persists.
  2. Check the signal strength: Weak signals can cause picture quality issues. Check the signal strength of your cable or antenna connection. If it's weak, you may need to reposition your antenna or contact your cable provider.
  3. Check the cables: Inspect the cables for any damage or loose connections. If you find any issues, replace the cable or reconnect it properly.
  4. Check the T-con board: The T-con board is responsible for driving the pixels on the screen. If the board is faulty, it can cause horizontal lines. Check the T-con board for any visible damage or burn marks. If you find any issues, you may need to replace the board.
  5. Check the ribbon cables: Ribbon cables connect the T-con board to the LCD panel. If these cables are loose or damaged, it can cause horizontal lines. Check the ribbon cables for any visible issues and reconnect them properly Check the LCD panel: If none of the above steps work, the issue may be with the LCD panel itself. A faulty panel can cause horizontal lines. In this case, you may need to replace the panel or contact a professional repair service.
Note: Opening the TV can be dangerous and may void your warranty. If you are not comfortable with opening the TV or performing these steps, it's best to contact a professional repair service.
3/10/2023 8:42:20 AM • Blue Computers &... • Answered on Mar 10, 2023
Vostro 1510 num lock and other blue lights blinking and on
It sounds like there may be an issue with the keyboard or the BIOS settings on your Vostro 1510 laptop. The fact that the num lock and other blue lights are blinking and on suggests that there may be a problem with the keyboard or with the settings in the BIOS. Here are a few steps you can try to fix the problem:
  1. Check the keyboard: Make sure that the keyboard is properly connected and that there are no stuck keys. Try to clean the keyboard, if it is dirty.
  2. Check the BIOS settings: Enter the BIOS settings by pressing the F2 key during the boot process. Look for an option to disable the num lock or other blue lights.
  3. Check the software: Check if there are any software updates available for the keyboard driver and BIOS on your laptop.
  4. Check the power management settings: Make sure that the power management settings are set to turn off the keyboard backlight after a certain amount of time.
  5. If the problem persists, it's best to contact Dell customer service or a professional computer technician for further assistance.
It's important to note that working with a computer's BIOS can be dangerous, if you're not comfortable working with BIOS, it's best to get it serviced by a professional.
1/23/2023 10:49:21 AM • Blue Computers &... • Answered on Jan 23, 2023
2answers
Charging i7S TWS attached to iMac USB port for 36 hours.... No Blue light yet!
battery is #1 failure on all portable devices! even 1 year old abused replace ok"?
4/8/2022 10:09:27 PM • Blue Computers &... • Answered on Apr 08, 2022
2answers
Dyson fan / Air Multiplier am01 won't turn on
problem in the engine
8/10/2021 1:04:44 PM • Blue Computers &... • Answered on Aug 10, 2021
Zagg keyboard - keys not responding, bluetooth light 1 not on.
https://www.google.com/search?q=Zagg+keyboard+-+keys+not+responding&oq=Zagg+keyboard+-+keys+not+responding&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
4/18/2021 11:27:41 AM • Blue Computers &... • Answered on Apr 18, 2021
Blue hawk 1034.1 manual
What is your question about that manual?
2/4/2020 1:22:53 PM • Blue Computers &... • Answered on Feb 04, 2020
How do I register for blue link
huh?
1/7/2020 4:10:43 PM • Blue Computers &... • Answered on Jan 07, 2020
Kaiser Baas are they blue tooth or wifi?
You'll need to specify what product in specific you are talking about - Kaiser Baas makes action cameras, scooters, VR displays and a bunch of other things. Suggest going to the website and locating the specifications for your model https://www.kaiserbaas.com/
11/25/2019 2:23:50 PM • Blue Computers &... • Answered on Nov 25, 2019
My printer makes blue marks
Clean it im guessing you have ink build up
8/10/2019 10:07:39 PM • Blue Computers &... • Answered on Aug 10, 2019
My computer has a blue screen error and I tried to install a new O.S but I think it worsens and now I don't know how to fix it
most folks cant, its a computer and are complex. all are. no PC stated at all just ATT? no OS stated windows 10? first in a shop we test the HDD first or look silly loading say w10 100 times and failing. most old HDD are dead, or fails smart tests. wana learn ask.
7/8/2019 3:42:42 PM • Blue Computers &... • Answered on Jul 08, 2019
I have a h p pavillion 15 notebook pc it powers on and goes to blue screen help it will not do anyting
Your laptop most likely has a corrupt file that windows needs in order to run properly. You did not state which operating system is on the laptop so it's hard to be specific. In any case, hit the F8 key as the laptop is booting until you come to the boot selections. From their you can boot into safe mode and see if that works. In some cases, this is all you need to do in order to reboot into normal Windows. If you see a "boot last known good configuration" boot into that instead of safe mode. If you cannot boot into last known good configuration or safe mode, you will need to insert your windows repair disk or your Windows Installation disk and run the repair tool.
5/15/2019 4:08:26 PM • Blue Computers &... • Answered on May 15, 2019
2answers
It has strong blue light on a bottom after changing battery but not on a display.
this sounds like your battery is ok but its not making right contact on your pc clean the contacts and reinstall it
5/2/2019 12:31:18 AM • Blue Computers &... • Answered on May 02, 2019
My pc encounterd blue screen problem...i want to stop it and i cant ... i want help to stop it
check memory ram.........and worst of it reformat....
3/26/2019 5:18:53 AM • Blue Computers &... • Answered on Mar 26, 2019
My PC will not open windows after update. Keeps trying auto repair, then I get a blue screen for advanced ootions. I tried to reset my computer to an earlier date, thata didn't work either.
Hi there, At some point during the process you copy of windows came corrupt- could be a result of improper updating, and sometime it windows itself. I forget which os but I remember this happening with an update- anyway if you keep getting the screen of ***** you need to reinstall windows from a flash drive or cd or whatever means you have to install it. It is also possible that you may need a new hard drive. Keep in mind that with many updates of many devices it usually accesses the memory to write the updated information to and if it looses power during the process it could damage the drive. Reinstall windows and be ready to buy a new drive. You can download windows 10 for free any other i think you need a key code to download. good luck
2/18/2019 2:33:50 PM • Blue Computers &... • Answered on Feb 18, 2019
Blue Coat Systems ProxySG SG210-5 Proxy Edition Security Appliance  Logo
Popular Tags
3 questions posted
Popular Products
Top Blue Computers & Internet Experts
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
vince
Are you a Blue Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Blue Computers & Internet
Most Popular Question
forgot applient sg210 4
  • Computers & Internet
