20 Most Recent
Cobra Digital DCA1030 Digital Camera Questions & Answers
How do I down load pictures off my camera
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
WHEN I TURN ON THE CAMERA AND TRY TO TAKE A
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Broken screen
it depends who u go to but i got mine fixed for about £50
3500Dvc camcorder wih mp3 player
Perhaps someone has one of these and will help, but I couldn't find out much about it on the net. I would suggest you take it into Best Buy- their techs and salespeople are pretty savvy, and should be able to show you how to work it.
The camera is pretty automatic, if you play around with the menu, you will become familiar with it.
Good luck, and hope this helps.
My open view is not showing any pictures but showing information about programs playing what might be the problem
Some steps you can try:
Check Picture Location:
Ensure that the pictures you want to view are in the same folder location. Sometimes, if the images are scattered across different folders, they may not appear correctly in the photo viewer.
Repair or Reset the Photo App (for Windows 11):
Go to Settings > Apps > Photo.
Click on Advanced options.
Choose either Repair or Reset to address any potential issues with the Photo app.
Enable Thumbnail Previews (for Windows 10):
Open File Explorer Options:
Type "file explorer options" in the Windows search bar and select the first result.
Switch to the View tab.
Ensure that the option "Always show icons, never thumbnails" is unchecked.
Click Apply and then OK to save the changes.
That is about all I can offer. If you repost, include brand and model.
4/19/2024 8:18:20 PM •
Cameras
Answered
on Apr 19, 2024
How do you turn on Digivue1.3? Has new batteries and used a while ago but pressing 2 button (Mode, Set) do nothing.
This is going to take patience and maybe the user guide. To turn on the Digivue 1.3, follow these steps:
Connect to Your PC:
Connect the standard USB cable (supplied) to a free USB socket on your PC.
The end of the USB cable should be connected to the socket on the back of the USB digidock.
Important: Do not connect any of the cabling provided with the Digivue before commencing the software installation.
Install DigiConnect Windows® Software:
Insert your Digivue into the docking station.
If you are connecting for the first time, a Red LED will display in the Activity Window of the Digivue.
Insert the CD provided into your optical disk drive. It will run automatically, and a dialog box will appear.
If the autorun feature is disabled on your system, browse to the disk using Windows® Explorer and double-click Setup.exe.
If you have a multilingual version of Digiconnect, you will be prompted for your language. Select from the list and click "Next."
Accept the terms in the License Agreement and proceed with the installation.
Choose the folder for software installation (default is the standard location for Windows® programs).
Click "Install" to begin the installation.
Leave the box labeled "Launch DigiConnect" ticked and click "Finish."
Wait for the Red LED:
Wait until a RED LED appears in the activity window of the Digivue.
You may now proceed with the next steps.
If you encounter any issues during this process, refer to the detailed instructions in the Digivue User Guide on page 9
4/1/2024 1:04:02 PM •
Cameras
Answered
on Apr 01, 2024
