20 Most Recent
Cobra Digital DC6550 Digital Camera Questions & Answers
Whenever i take a one picture with my camera it
Hi!
Some cameras have a limited internal memory. To make more space on your camera, you need to connect it to a computer to move the pictures in there, or to add a external memory space to your device like a memory card.
However, you should know that memory cards have different sizes and you need to check your camera to see what type of memory card accepts.
I hope this will help you!
Have a nice day!
*please don't forget to rate my services :)
I dropped my camera and
Hello
The problem is that the lens has become stuck in the barrel
after dropping it. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful.
Regards
Andrea
Cobra DC6550 camera
you need to insert the memory card in the slot in the bottom of the camera until it clicks
Saved pics
Hi,if dont have any very important picture stored in camera you may reformat it all protect picture will erase , the camera sim has no more vacant its full you connot store picture anymore best solution is to reformat it.press menu , press setup,navigate down select format. then okey.
Can not install soft ware
Here are the drivers for your camera
http://cobradigital.com/drivers.php?cat=1
4th link from the bottom
Model DC6550Select the link above to begin the download process."
If that doesnt fix it let me know! Good luck.
COBRA DC6550
Hi ill have a look now for you and let you know what you need to do ok bare with me for few minutes ok
COBRA DC6550
Hi , replace full charge battery , rotate knob to manual,press function set ,navigate down select awb, hen press navigate right select what ever liht you are using indside the house if bulb select bulbthen press function set.
use also 100 iso , metering number set to "o" , colors set to "colors off"
Picture taking
Hi , need a flush , set camera to flush navigate press auto or flush sign.
set camera in manual , press function set , navigate to awb an auto , set icon flourescent press function set , then okey
DC6550
We need to be sure of some things:
Are you saving the picture to the internal flash memory or an external SD card?
1) The internal memory will only hold 16MB of pictures, check if it's full.
2) The external SD memory can only be up to 1GB in size, anything bigger will not be recognized by the camera
1. Make sure the SD card is not "locked". Some SD cards have a little switch to prevent them to be written into.
2. SD card should be formatted by the camera preferably or as the FAT format in your PC.
Does this help you in any way?
Please give us more information as to how you are saving them and/or any further questions you may have.
