20 Most Recent Craftsman 17029 Wet/Dry Vacuum Questions & Answers
Craftsman wet/dry vacuum
my last post was supposed to be a solution.
5/31/2009 9:28:56 PM • Craftsman 17029... • Answered on May 31, 2009
Troubleshooting
Plug the hose into the other side of the unit. One end pushes air and the other side draws in the air. Now drywall dust will clog your filter quickly. Clean the filter often. Do not clean dust without the filter. It will get all over everything!
9/1/2008 1:00:38 AM • Craftsman 17029... • Answered on Sep 01, 2008
How to reassemble a Craftsman Staple Gun model 968514.
There are no schematics because you aren't supposed to take them apart. You can sent it back or just buy a new one. https://www.manualslib.com/manual/1739428/Craftsman-Easy-Fire-0993056.html#manual ..
10/25/2023 4:48:48 PM • Craftsman... • Answered on Oct 25, 2023
Where is the thermal fuse on my craftsman 5.0 HP shop vac?
I don't know exactly but if it has one it will usually be found in intimate contact with the motor. Some vacs were fitted with a bimetal breaker which is also sited close to the motor, but sometimes there is so much dust around once they open they fail to make a good contact again when the cool and close. Older vacs weren't fitted with any safety devices.
11/11/2017 11:22:58 PM • Craftsman... • Answered on Nov 11, 2017
Install power switch to a craftsman vacuum cleaner
Yes, you need to take it apart. Maybe ask a friend who knows Mechanics or Electrical.
9/1/2017 11:07:19 PM • Craftsman... • Answered on Sep 01, 2017
I have a Craftsman wet
Most wet dry vacs have a ball float that blocks the vacuum when it is full of liquid. Yours sounds as if it is full or the ball has gotten stuck in the up, or blocking position.
7/4/2017 2:01:01 PM • Craftsman... • Answered on Jul 04, 2017
Do i need to remove filter on my craftsman to vac up wet
Absolutely yes. If not, the filter will be saturated with water and ruined.
11/2/2016 7:50:11 PM • Craftsman... • Answered on Nov 02, 2016
How do I get the craftsman 79470 to vacuum?
First check if the bag is full. Then check if hose is clogged or attachment is clogged.
3/6/2015 12:23:29 AM • Craftsman... • Answered on Mar 06, 2015
2answers
Craftsman 8 gal wet dry vac 113177011 runs and sounds like motor surges and backs off also smells hot
Check that water cut off is not sticking on.
11/9/2014 5:56:01 AM • Craftsman... • Answered on Nov 09, 2014
T.he light on the garage
Either the bulb blown or not wired right when installed. should have one red wire, one black wire and a ground wire, green or copper.
5/27/2014 6:28:02 PM • Craftsman... • Answered on May 27, 2014
0answers
0answers
0answers
0answers
0answers
Craftsman 17029 Wet/Dry Vacuum Logo
4 questions posted
Top Craftsman Vacuums Experts
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Vacuums
  • Craftsman Vacuums
Most Popular Question
troubleshooting
  • Vacuums
