SOURCE: Central Vac will not turn on.
These problems are nearly exclusively caused by a bad circut board and replacing it is the fix. Bad boards can cause many different effects so its nearly impossible to be sure. The 9v signal wire is not enough to short out an entire unit so it is unlikely the hose. If it is a direct connect system and you are pulling power from the 110 somehow that would cause main unit problems but that is unlikely at best. Sounds like a failed board to me.
Best of Luck
SOURCE: what if i use my wet dry vac to pick up water
DO NOT USE A FILTER WHEN PICKING UP WATER!!!!!
Im certain if you check the instruction manual it says to remove the filter.
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
SOURCE: I do not have my
Vacuuming Liquids
1. When picking up small amounts of liquid
the filter may be left in place.
2. When picking up large amounts of liquid
we recommend that the filter be
removed. If the filter is not removed, it
will become saturated and misting
may appear in the exhaust.
3. After using the vac to pick up liquids,
the filter must be dried to reduce the
risk of possible mildew and damage to
the filter.
4. When the liquid in the drum reaches a
predetermined level, the float mechanism
will rise automatically to cut off
airflow. When this happens, turn off
the vac, unplug the power cord, and
empty the drum. You will know that the
float has risen because vac airflow
ceases and the motor noise will
become higher in pitch, due to
increased motor speed.
IMPORTANT: To reduce the risk of damage
to the vac do not run motor with float
in raised position
