20 Most Recent Honda 2006 AquaTrax R-12X Questions & Answers
Honda outboard motor
Congratulations
11/12/2021 5:02:15 PM • Honda Boating • Answered on Nov 12, 2021
What is the plug gap for a 1989 45HP Honda outboard
Set it at 0.6mm
.024''
5/26/2019 10:41:09 AM • Honda Boating • Answered on May 26, 2019
2answers
My honda 50 4 stroke outboards trim and til gou down but do not want to go up please help. There are no leaking and the oil is full but the trim and tilt stil do no go up.
Hydraulic fluid is most likely low. Refill it, then work the motor up and down about four or five times. Recheck and refill reservoir. Run up and down several times until you get a smooth up and down motion. Recheck /refill. Any air in the line will work it's way out on it's own. Be sure to look for any leakage.
11/24/2018 4:05:14 PM • Honda Boating • Answered on Nov 24, 2018
What year is my 15hp Honda motor series 1201940
If you go by the numbers it looks like December 1940 If its an old one this sounds about right.
8/23/2018 12:58:26 PM • Honda Boating • Answered on Aug 23, 2018
Oil problem on a 1996 50 hp Honda outboard
It's a little vague . What's the problem ? Over heating , fuel in oil , water in oil? Over heating will be a water pump problem , water in your oil is a bad head gasket, fuel in oil is passing rings . Honda's are great engines but they must be broken in properly .
8/4/2018 8:42:30 PM • Honda Boating • Answered on Aug 04, 2018
I need a diagram of carb choke and throttle linkage for my honda 8hp 4stroke outboard motor
6/26/2018 8:21:01 AM • Honda Boating • Answered on Jun 26, 2018
2answers
Honda 50 marine outboard stalls at high revs
Those systems have an injector + mechanical pump... check the fuel line to see if its getting a restriction . And the filters.. If not there check the float bowel located on the right side ( standing behind the boat looking forward. It's located under the air intake...if it isn't allowing enough fuel in you'll stall. Honda is a good engine but the engineers got lazy when they left half of the system efi and half mechanical.
4/26/2018 6:17:59 AM • Honda Boating • Answered on Apr 26, 2018
I can’t move the selector shaft on my bf6 b Honda outboard after changing impeller. What have I done wrong
haven't line up the selector shaft with it in neutral pull the leg off and do it again
3/10/2018 10:25:29 PM • Honda Boating • Answered on Mar 10, 2018
BF 90 Honda outboard over heating in the lower section ?
The first things to check are the Thermostat and the Impeller. Also make sure there are no blockages in the water intake. Have you checked the lower unit oil? If you need further help, I’m available over the phone at https://www.6ya.com/expert/saam_2816e29ba1070532
11/25/2017 4:11:54 PM • Honda Boating • Answered on Nov 25, 2017
I HAVE A 2006 HONDA 115 FOUR STROKE ENGINE ON MY PONTOON BOAT. HOW DO DIRT DOBBERS GET INTO THE INNER WORKINGS OF THE MOTOR AND HOW DO I PREVENT THIS FROM HAPPENING?
the term dirt dobbers is not known out side your area so you will have to give a detailed lo what they are so that an answer can be given also when you say inner workings are you referring to the cooling system , the sump or the fuel system
10/16/2017 9:24:00 PM • Honda Boating • Answered on Oct 16, 2017
My honda 40 hp boat motor the alarm goes off when the key is on when t put it in reverse or forward I unhooked the linkage and when i hooked it up the alarm goes off
It's normal if you remove the cable harness, the alarm goes off. Check your engine oil level. Disconnect the engine temperature sender. If it then stops sounding, replace the sender. Does the alarm still sounds when the engine is running? Does the engine has had his maintenance? Maybe you can post the exact engine type, so we can look for the exact alarms wiring system...
10/1/2017 9:09:24 AM • Honda Boating • Answered on Oct 01, 2017
HONDA OUTBOARD #BACL1209812 INFO
6/3/2017 7:28:31 PM • Honda Boating • Answered on Jun 03, 2017
2006 honda 4 stroke outboard 200 hp getting water in crankcase
You have a leaking head gasket or cracked block.
10/25/2016 10:51:46 PM • Honda Boating • Answered on Oct 25, 2016
Honda 2006 AquaTrax R-12X Logo
0 questions posted
Popular Products
Top Honda Boating Experts
ROBERT GARCIA
ROBERT GARCIA
Kardoc
ADMIN Eric
ADMIN Eric
Are you a Honda Boating Expert? Answer questions, earn points and help others
View Most Popular
AquaTrax R-12X Honda
  • AquaTrax R-12X Honda
Most Popular Question
honda 50 marine outboard stalls high
  • Boating
