Boating Logo
M
MICHAEL GAFFNEY Posted on Jul 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to replace the impeller on my Honda 8hp trolling motor. S/N 1203060.
Steve P
Level 3:
  • Honda Master 3,912 Answers
  • Posted on Jul 02, 2017
Steve P
Honda Master
Level 3:
Answers
3912
Questions
5
Helped
1307688
Points
15904
Looking at a bed edger and the compression is 90 psi is this something that i should worry about.
The Honda 8HP motor will work OK with 90 psi compression but it's on the lower end of good. Most likely it will need new piston rings and possibly the cylinder resurfaced in the near future. Low compression could also be caused by valves not seating completely either from wear or carbon buildup. Depending on what you are looking to spend it may be worth your while to remove or have removed the head to inspect the valves and cylinder wall.
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
4helpful
How much oil does an 8hp honda engine take ?
Honda gx240 oil capacity
1 .I6 US qt
Use Honda 4-stroke oil, or an equivalent
high-detergent, premiumquality
motor oil certified to meet or
exceed U.S. automobile manufacturer's
requirements for Service Classification
SE or SF. (Motor oils classified
SE or SF will show this designation
on the container.)
SAE low-40 is recommended for
general, all-temperature use.
4helpful
Won't start, new coil, weak spark,
if i remember correctly these have electronic ignition the module may need replacing but beforedoing any thing drastic try disconecting the oil alert wire that sometimes gives a bit of pain youdoit
Honda 8HP GX240 willnot start after working fine.
Your carberator has crud, or rust, or glaze in it. The carberator will have to be removed, soaked in cleaner for three hours and then rebuilt using the proper carberator kit from any auto parts store. If you need to hire this done expect to pay about 35 dollars.
Battery to starter motor.
Just to be clear, the starter should have a large terminal (where the battery cable connects) and a smaller terminal (where the activation wire connects)
The starter is grounded via the mounting bolts.
The activation wire runs from the starter to the starter switch.
Aduz
Top Honda Boating Experts
ROBERT GARCIA
ROBERT GARCIA
Kardoc
ADMIN Eric
ADMIN Eric
Are you a Honda Boating Expert? Answer questions, earn points and help others
