20 Most Recent
ICOM Informatique Icom F21GM GMRS Radio with 4 Watts Output, CTCSS and Battery/Charger Questions & Answers
R71A replacement of the DP-2 Matrix Board
The best source of info is Paul Hansen in Columbia, SC. He is an ICOM approved warranty service tech, and the last telephone # I have for him is: 1-864-222-3539. He fixed an ICOM IC-2100H for me four years ago, and I was very pleased with his work, and repair cost. At least, give him a call. I do not think you will be displeased with him.
Longshorts.
7/24/2009 10:05:25 PM •
ICOM...
Answered
on Jul 24, 2009
Hand-held radio
Hello Think you have to make sure that both radios have the correct encode and decode CTSS or DPL, if you dont select the encode for one of them the other one just will light the green led but will not recieve.
Also make sure that the speaker is working correctly.
Check your programming parameters one by one.
Good luck
12/9/2006 9:23:15 AM •
ICOM...
Answered
on Dec 09, 2006
Icom bc-179 do not charge the battery
Charging a battery requires two components. A working charger and a functioning battery. The concept is simple. A battery charger must output more voltage than the battery does, and at an acceptable current level. First determine the battery output from the ID sticker, then measure the charger output. It must be 1 or 2 volts more than the battery output. If the charger is working, charge the battery overnight. If the battery does not charge or runs down quickly, the battery must be replaced. All batteries have a limited number of charge cycles. The most common problem with Ni-Cad batteries happens when they are re-charged before they are completely discharged. Recharging a half used Ni-Cad sets up a short term memory and the battery discharges faster than normal.
12/30/2016 5:56:30 AM •
ICOM...
Answered
on Dec 30, 2016
Can't get icom a6 radio unlocked
Copied this from their manual:
The lock function prevents accidental frequency changes and accidental function activation. q Push (looks like f) , then push [7• ] to turn the lock function ON. •" " appears. (looks like f) To turn the function OFF, repeat step 2 above. •" " disappears.
http://www.icomamerica.com/en/products/avionics/handheld/a6/default.aspx
9/21/2016 6:48:10 AM •
ICOM...
Answered
on Sep 21, 2016
How to repair ic-v8 tuner
In the USA, repair and service of a radio frequency transmitter requires a 1st, 2nd, or 3rd class FCC license. The other bad news is the radio probably uses a solid-state chip for tuning, so special tools will be needed to remove and install a new chip. This is best left to a factory repair center.
5/30/2014 5:10:06 PM •
ICOM...
Answered
on May 30, 2014
ICOM IC-320S-6
No, it cannot be "narrowbanded".
5/19/2014 5:12:07 AM •
ICOM...
Answered
on May 19, 2014
Ic-v85 battery wont charge
battery pack already exhausted or your charger is defective, check your charger by using voltmeter, if there is voltage output more than your battery voltage that means your battery needs replacement.
12/24/2013 3:43:33 PM •
ICOM...
Answered
on Dec 24, 2013
Zartek 705 and 708 2 way radios
The
705 will operate on (8) frequencies in the 446Mhz range and (5) in the 464Mhz range. The
708 operates on 446Mhz. Please note that the links provided mention they operate in "public frequency band" of South Africa. These radios were not intended to be used in other countries. See below for more.
In the U.S.(and many, many other countries), the 420Mhz - 450Mhz frequency range is set aside by the FCC (and other bodies) for licensed operation by amateur radio operators. Portions of the 460Mhz range is set aside by the FCC for use by Public Safety Agencies - mostly local police and fire departments. In the U.S., the Family Radio Service (FRS is 462Mhz) is an unlicensed band and General Mobile Radio Service (GMRS is 467 Mhz) requires a licensed.
As you might have guessed, unlicensed or unauthorized transmissions are ILLEGAL. You may be fined, imprisoned or both if caught by the FCC. If using these radios in a location other than South Africa, consult that county's communication authority BEFORE transmitting. You cannot transmit legally in the U.S. with these radios.
11/19/2013 8:06:27 PM •
ICOM...
Answered
on Nov 19, 2013
Icom IC-F3GS witch is the unlock key?
Try looking up the user manual at www.mods.dk they have many manuals. Otherwise you may be able to get the manual from www.icom.com.
11/5/2013 5:39:00 AM •
ICOM...
Answered
on Nov 05, 2013
