20 Most Recent
Hayward PRO SERIES 27" SAND FILTER W/1.5" VALVE - Questions & Answers
Since day 1 I have has sand in my filter Have
Sand in your filter or sand in your pool? A common mistake when installing these is not to fill them half way with water prior to filling the tank with sand. Failure to do so often leads to cracks in the lateral assembly and sand in the pool. If that is the case you'll need a new lateral assembly, part #SX210DA. Depending on how long ago it was installed and who installed it you may be able to get the part under warranty. If not it runs about $45.
The filter takes 200# of sand. Your product tag should confirm this with a statement of something like "media required: 200#" or something similar.
John
Hi, went through the process of using sand filter
Sounds like you may have a bad spider gasket in your multiport valve or possibly a weak spring. Do you ever notice water coming out of the backwash while your system is set to filter? Another possibility is your screen on the air relief tube inside the filter is not in place, this will allow debris back into the pool but not alot, most if it would get filtered. Also, make sure your multiport valve is installed correctly and is set to the proper mode. There is a recirculate mode that will allow everything to bypass the filter. The label may even be incorrect.
Hello,\r\n I'm running a 3 year old 1.0 hp
Thank you for posting your question here on Fixya.com.
Check the stator for a ground-fault using a megger or a ohm meter. If it smoked it is likely even an ohm meter will show a ground; if it is not grounded check for resistance across the line connections. A typical single phase motor will be about 1 ohm. If it is zero ore some number below .5 the winding is shorted. A winding that smokes is nearly always best to be replaced. Even if you get it running again it is only going to be for a short time. I would not change the horsepower if the pump had been keeping the pool clean prior to the mechanical and/or electrical trouble. If you do you'll need a new impeller too since changing one without the other is pointless. Was the pump leaking as you began to have these troubles? Have you confirmed the incoming line voltage is 220V and stays at least 208V or more under load? You may have had an underlying problem with voltage drop or a leaking seal that caused the failure that you will want to address to prevent this from happening again.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
Weed trimmer (2 wheeled) screeches.
All questions need full 'make model (what is is)' as first 3 words please. Very often, issues like this are a known fault and users tell the fix.
You need to track down where the screech is coming from?
Wheels
Drive Belt
Bearings
Piston rings
Or it may be battery operated?
4/24/2024 10:27:50 PM •
Garden
Answered
Yesterday
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow:
Check the Seals and O-Rings:
Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve.
Unscrew the pump: Remove the pump to access the internal components.
Inspect the seals and O-rings:
Look for any damaged or worn-out rubber seals.
Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place.
Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease.
Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube.
Reassemble the pump: Put the plunger back into the tube and lock it with the handle.
Test the sprayer: Pump it up and check if it maintains pressure without leaking.
Inspect the Handle and Hose:
Handle connection: Ensure the handle is securely attached to the cylinder.
Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose.
Check the Nozzle and Wand:
Nozzle adjustment: Adjust the nozzle to the desired spray pattern.
Wand inspection: Examine the spray wand for clogs or obstructions.
Lubricate O-Rings and Seals:
Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation.
Test the Sprayer:
Fill the cylinder to the desired level (avoid exceeding the maximum fill mark).
Screw down the pump firmly to create an airtight seal.
Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM •
Garden
Answered
2 days ago
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
on Apr 20, 2024
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM •
Garden
Answered
on Apr 17, 2024
