Brand is Hitachi
SOURCE: Echo 260L no power, will start but not run
Check the insulator block for cracks and the 2 gaskets behind it. Make sure the gaskets are lined up properly.
SOURCE: Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Testimonial: "Great reply thank."
SOURCE: PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
SOURCE: weedeater blower will not prime
The bulb is a two way valve. The inlet from the gas tank is shorter than the longer end, which goes to the carburator
