20 Most Recent
Philips Zenia 300 TU7370 Cordless Phone Questions & Answers
Trouble is it fell in to some (water handset only)
sounds as its still damp inside of handset. u could strip down and make sure the water hasnt coroided any contacts which is making it discharge to earth.
with regurds replacement handsets , i have been looking for spare base as mine is just started going and cuts calls off ( sound like dry joint in base unit or power supply is giving up) try a philps dealer to see what spares philps have other than that it secound hand units.
Messages that dont exist and cant be deleted
With regards to this query we would advise that you reset the software in the telephone's base station.
To complete this process, please implement the following:
1) Disconnect the power cable from the main base station.
2) Remove the batteries from all of the handsets.
3) Leave for 5 minutes and then connect everything back again.
Please note that this process will not delete any telephone numbers from your phone book or any other saved information.
If applicable, you will need to set the time and date.
Philps Zenia 200 Cordless Phone -- Voice mail problem
It might be worth resetting the software for teh phone. Not sure if it is the correct solution, but it might be worth a go.
Instruction booklet
I would suggest you look at the manuals for other Panasonic KX-T .... models. The basic operations are nearly about the same. I did the same for a BellSouth cordless I got on the cheap on Ebay. Could not find a manual for the exact model but searched on the web and managed to get all the basics by looking at the manual for a near identical newer model. Look out for similar type buttons and general layout and you will get some idea about the operation. Good luck with it.
Philips CD130 flashing 'Warning'
You need to dry it out completely. A few centrifugal swings around your shoulder might remove much of the water. Then try one of these drying methods: Place it on a register or AC vent for a day or so might be the best way to get it dry.
Afterwards, (if trying to operate it didn't short out a component,) it might work again.
