Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
Posted on Sep 01, 2008
Panasonic tv model pt-50LC14 will not turn on
Where in the console is the lamp located? do i have to take the whole tv apart?
Anonymous
Level 1:
  • Contributor 44 Answers
  • Posted on Sep 02, 2008
Anonymous
Contributor
Level 1:
Answers
44
Questions
0
Helped
8851
Points
92
First, turn off the tv. Once the fan has stopped, unplug the tv. Remove the front cover from it latches (takes up most of the area below the screen). On the left is the lamp door. One screw holds the door. Remove lamp door. Looks like one screw holds the lamp assembly. Loosen screw and remove lamp. Lamp may be hot if the set was running before you began the lamp replacement.
If you have a new lamp assembly, reverse the process. If a new lamp without assembly, change lamps. CAREFUL. No fingerprints on the new lamp. The oil in the fingerprints will shorten the life of the new lamp.
Reset lamp hours in the menu when done.
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
3answers
Should I replace my lamp for my Panasonic 1080i htd t.v. pt-50LC14
Replacing a lamp won't work. There is not even one lamp in your TV. I'm afraid the lightening has done more damage than can be repaired. Even when some tech manages to repair te error, the TV can have the next error in days or weeks.
Try reading something about ESD. Electro Static Discharge and what it does to electronics. Electrostatic discharge
I have a panasonic PT-50LC14. the tv will turn on, but there is no picture. do i need a new lamp or bulb?
It is possible if over two thousand hours of use or two years, I would suggest at least removal and inspection to see if lamp shattered.
3helpful
My panasonic pt-50lc14 turns off the power light flashes red and temperature light flashes.
Examine the lamp first and be aware the model 50lc13 and 50lc14 which are almost identical had all sorts of problems----the lc13 was part of a massive recall/exchange that cost Panasonic tens of millions of dollars.
could be lamp or even the ballast which was the real issue involved in the recall.
3helpful
Where is the lamp housing for the Panasonic
The lamp housing is located behind the front cover panel.When you open the front panel you can access the lamp unit screw.
thanx
11helpful
2answers
Lamp reset on a panasonic model pt-50lc14-k
This works for mos Panasonics
Turn on Power
Pres and hold the "vol-" button on the front of unit and the "split" key on the remote together for over 5sec.
Screen should say " Lamp time was reset to 0"
How hard is is to replace the lamp in the PT 61lcx65 tv? The green light is on but the tv screen is blank Thanks
Howdy,
The lamp is really easy to replace. It is located on the right side of TV. Panasonic Lamp's come with directions.
Thanks for using FIXYA, BIG IRISH.
2helpful
Reseting The Projection Lamp Hours Meter
If you need the original remote, you can order the original Panasonic replacement remote control for this model (PT-50LC14) from a major Panasonic parts distributor at the link below:
Panasonic PT-50LC14 Replacement Part Remote Control
Sometimes there's a way to reset the counter by mashing certain keys on the TV itself in a sequence, but if your owner's manual doesn't specify this option, then you may have to get the original replacement remote to be able to reset it.
3helpful
Panasonic pt-50lc14 lamp needs replaced.
You will find this very easy. Take the front panel off. It just pops off. Two screws..one on the out side door and one inside the door. You can do it from there. Oh yea put the back of the Tv back together....lmao.
PT-50LC14
Hey Beestergirl, I just had my tv fixed for 385.00
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
