Replaced projection lamp but lamp does not turn on and instead of blinking green power indicator I...
(More)
Replaced projection lamp but lamp does not turn on and instead of blinking green power indicator I am receiving a blinking amber lamp
My television wont turn on, I came home today no power outtages and all the other equipment is...
(More)
My television wont turn on, I came home today no power outtages and all the other equipment is perfectly fine. My Televison wont turn on and doesnt respond to either the remote or the mannual switch. Have tried changing plugs and resetting the surge protector....is this thing dead or what. It is a Panasonic HDTV TAU....HELP!!!
my panasonic pt-50lc13 when i turn on the power the green light blink normal for about 3 seconds...
(More)
my panasonic pt-50lc13 when i turn on the power the green light blink normal for about 3 seconds then start blinking faster and thats all they do.
replaced lamp t.v comes on for a few seconds then it goes off. power goes from green to yellow then...
(More)
replaced lamp t.v comes on for a few seconds then it goes off. power goes from green to yellow then blinks 7 times.will not come back on.
The TV just went out went watching it and will not turn back on. Is there a re-set button. Please...
(More)
The TV just went out went watching it and will not turn back on. Is there a re-set button. Please advise
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
