The receiver doesn't have a password, but the unit can be fried, let's go with by a process of elimination.
First, the most noticeable procedure would be to not plug in anything in back of the receiver, and plug it in the an outlet and turn it on. If the unit shuts off after a few seconds, then the unit has a short and must be sent in for repair.
If the unit stays on, then there is something that is being plugged into the Receiver that doesn't seem to agree. Start by plugging in one source at a time and repeating the step above. It's a slow process but hopefully and eventually, you will find the culprit.
In most cases though, it usually the speakers wires in the back touching even a slight bit or your speakers impedance don't match what the receiver is capable of taking.
I strongly recommend starting with the first step since this will allow you to figure out if the receiver is defective or is something else the culprit.
Hope this helps, Best of Luck
