Often the floor of the passenger side become wet if the drain pipe of the evaporator is:
- Bent or twisted.
- Clogged or,
- There is any obstruction in its routing.
The drain pipe is a rubber hose about 14 mm in diameter, located just under the evaporator (cooling coil) casing on the passenger side.
The most easiest way to clean the pipe is to take it out, wash it from inside with water or to blow a compressed air slowly through its distal end while leaving it in place under the body.
Note: Keep your eyes away while blowing the air.
Hope that it works.
Check whether the warm air isn't going in with the cold air .Coolant line that runs into the firewall on the passenger side of the engine which is toward the bottom half of the firewall on the passenger side. If there is warm air going into the vents with the cold air then it blows warm air. You may have to shut it manually because it gets stuck sometime. Check it out.
If you look on the firewall on the passenger side there should be a drain hose for the A/C under the evaporator, these can get clogged over time and cause water to puddle on the floorboard. Just take a straightened out clothes hanger and push it up into the drain hose breaking up any blockage in there.
To replace the blower motor, take out carpet under glove box. look under glove box. there should be
three screws to take out and then just pull out the old blower motor.
Sounds like condensation from the air conditioner evaporator. This is perfectly normal. Often the a/c will be run with the heater, especially when you use the defroster, as this dries the air and keeps the windshield from fogging up.
That's not good! Are you finding puddles under the vehicle, or is your passenger side carpet wet? Is there any odor to the air. If any of this is yes, your heater core may be going out.
You may want to have the evaporator (the AC part under the dashboard on the passenger side) cleaned. It needs to be taken out and cleaned. Normally this would solve the issue. Have the freon checked if there is a decrease. You may have it filled up and have the system checked for leaks.
