Most GE washers you have to open or remove the back cover on the washer.
You should see the motor and belt near the bottom of the unit.
Most GE use the motor mounting bolts to also adjust the drive belt.
If you loosen the belt by pushing the motor closer to the small pulley, it will easily come off over the smaller pulley.
Watch this video and it will show ya how to replace the belt...http://youtu.be/BNwSQh7GayE
if ya need to copy and paste the link its for a youtube video
SOURCE: GE washer will not spin
replace the lid switch located under the switch as most likely a wire has broken off this switch and is usually not repairable,remove the front cover by using a putty knife near the top of the front cover to dislodge the clips,then remove front cover and the wires to the switch will be near the right side of the tub leading to the underside of the tub and you can then remove top cover to replace this switch
