20 Most Recent GE Spacemaker GTUP240EMWW 24" Electric Laundry Center with 2.2 cu. ft. Washer, 4.4 cu. ft. Dryer, 9 Questions & Answers
there could be a fuse in the control board that you can look at
other than that get in a technician as the unit could be damaged from the power surge
GE Washing... | Answered on Mar 22, 2019
It may be a cracked drain hose behind the drain/ clean out cap
or a loose clamp.
i had the same issue and fixed this myself in less than 20 minutes.
I also removed the drain cap and found missing laundry items and
a few other items blocking the system.
If you have not googled or checked you model online
you can find out the location of this cap, which is normally
behind the bottom front plate on your washing machine.
Generaly on the right side.
GE Washing... | Answered on Mar 08, 2019
Drain pump may be clogged or screens in hoses and water valve may be stopped up
Unplug it for 15 min..
Cheers
GE Washing... | Answered on Mar 07, 2019
It's going to cost you if your not handy as the problem is more than likely a small board which sends a message to a relay, but not the relays of the good old days.
GE Washing... | Answered on Feb 18, 2019
check the breaker. is it a gfci?
GE Washing... | Answered on Feb 17, 2019
GE Spacemaker GTUP240EMWW 24" Electric Laundry Center with 2.2 cu. ft. Washer, 4.4 cu. ft. Dryer, 9 Logo
2 questions posted
Top GE Washing Machines Experts
Marvin
Marvin
jimorris77
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
older ge washer pull out knob not
  • Washing Machines
