Bonjour Je viens de monter mon SPA Intex et mis en route Apr?s avoir r?chauff? l'eau jusqu'? 17 il a bugu? et met une erreur E98 J'ai appuy? sur reset mais rien n'y fait As tu une id?e pour me sauver Merci Bises
bonjour jaimerais bien savoir jai un viewsat 2000 ultra et jai fait mes mise a jour et jai les poste de radio et de chaine sauf il m afiche le signe $ et crypter et jai une coupole de bel allor comment avoir une cle ou un code pour avoir les chaine merci beaucoup et je vais attendre votre reponse ah aussi pourier vous me l ecrire en francais car je ne lie pas en anglais
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
the developer home position sensor is not registering. it will need to be cleaned. This will involve the removal of the left side cover, the removal of the power supply pcb and the removal of the sensor which sits under the power supply. clean the sensor out with a dry pain brush and re install. be careful to turn the printer off and unplug it prior to removing any covers. the cover is easily removed, however, take your time and make sure you release all the clips on the inside of the cover. once the cover is off it is easy to get to the sensor. don't worry too much about all the connections to the power supply, they only fit in one plug and cannot be inter changed.
Remember to take your time in this operation. If you are at all uncomfortable with this, do yourself a favor and call a technician in to do it. He wii do it in about fifteen minutes.
