Posted on Jul 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Epson printer R32o won't print color . All cartridge all new . Please help ! .
Saleem Baig
Level 2:
  • Expert 283 Answers
  • Posted on Jul 16, 2011
Saleem Baig
Expert
Level 2:
Answers
283
Questions
0
Helped
62495
Points
806
Hi
Have you checked the settings if they are set to Grayscale only or use black cartridge only. Options in printer settings? try to restore all to default settings and this will solve your problem.
Take care
Epson black ink only won;t work unless I have full color cartridge as well. What a piece of garbage! Never buy Epson again unil they solve this problem. I'm out of blue but I can't use a bl
The way around Epson ripping you off is to use compatible cartridges. They are much cheaper than Epson and will work in most printers. You can buy them in bulk from places like Amazon. As for the print quality I have not noticed the difference. Some printers might say that you are not using Epson ones, but you can dismiss them and carry on.
2answers
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
My epson xp-200 printer with won't print with the recommended ink cartridge epson 200. why?
The printer may only work with Epson ink cartridges and not compatible ink cartridges.
Ink shows full but color won't print
Uncommon faults are with the electronic drivers in the printer system that drive and control the printer cartridges. This is providing the cartridges are proven to not be defective. Also, jammed nozzles will prevent printing.
Make sure your software is not set to print in monochrome (B&W) only .
Jerry G.
1helpful
Installed new black cartridge in Deskjet 810C printer and after doing this it will only print in pink color. Please help.
Make certain that the cover is off the jets - if you forgot to pull the strip off or it broke leaving part of the tape on the cartridge, it won't work. Try to do a clean process on the cartridge. If that doesn't work, and you don't have another printer to try the cartridge in, return it to the place you bought it and get another new one. If the printer is printing pink, the color cartridge is probably empty also so that it cannot make black from the other colors. These sound like refilled cartridges - OEMs would have failed with some form of error code or warning.
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Non printing epson c20ux
Sounds like color cartridge ran out. Were u using color to print black?
Try new color cartridge.
Then if you don't need color go in and set to use black cartridge to print black (text).
If you need color on something only takes a minute to turn color back on.
Since printer worked you can go in and select black which uses the black cartridge and if it prints gives validity to a bad/empty color cartridge.
Good luck.
JC
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
