you need a new clock it operates seperately from the eyes. if you have 110 volts to it and it is not illuminated .it is out
SOURCE: No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
SOURCE: Claibrating the temperature of a GE gas oven
5 degree increments from factory setting
1 is +5
2+10
and so on
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
To bayziepepper. Thanks so much. Had the same problem as those above and pressing the black button solved the problem. Now, I don't need to call the repairman.
As for shannon603, I think he/she has his/her own particular problem (and not only with the oven).
SOURCE: GE Profile electric range: I'm getting an F0
Hi greengib,
The Failure code "F0" description is a stuck touchpad. Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope it helps.
Thank you for using FixYa.
