I need to purchase a 40-4096 speaker compatible to it. This item is discontinued at Radioshack, I eill like to know a substitute of it. Please send new model, and manufaturer in order to download specifications.
Please Note: The original remote (VS5043) is no longer available. The remote below is the recommended substitute remote. Substitute
remotes provide similar functionality to the original, although there
may be minor differences.
VS5043 Original Remote Control
VS5043 Substitute Remote Control
link to buy
about speakers can you tell me that are you able to hear sound from speaker or not.or is it the remote that showing no speaker..if it is showed by only remote then no need to change speaker ,but if speaker are not working at all then you need to change speakers........ check through t.v volume button that sound comes or not.
Since this is a radioshack product, you can download the files thru their website. The only problem there is if radioshack discontinued supporting his product. Please click this link. As on option, if you need to transfer your pictures from your camera to your computer. You can purchase a card reader then all you need to do is to take out the memory card of the camera and insert it to the card reader.
You can find a list of compatible adapters here http://usa.canon.com/cusa/consumer/products/calculators/printing_calculators/p23_dh_v#SuppliesAndAccessories Also, you can look at the AC adapter plug on the calculator itself and read what it says. Typically it'll say something like 12v + --o)-- - which means 12v plus in negative charger. You can then go to radioshack or the like and pick up a charger from them, though with the prices I see on the canon site, I don't know if you'll get a $8 charger from radioshack.
You need a AC to DC power supply capable of supplying 120VAC in, 12VDC out @ 1 amp (1000 mA). The center of the plug must be + and the outside -. I believe Dell supports these speakers and may have the power supply available. Radio Shack might have a substitute PS as well, you just have to match the plug size. Be careful what you pay for it, a new pair of these speakers can be purchased for around $20.
Here is a 12v 1500mA adapter (the mA rating can be higher that what you need, but not lower) from Radio Shack http://www.radioshack.com/product/index.… but its more expensive that a new set of speakers.
Yes. There is one more mapset and then there will be no more for us using the StreetPilot 2620. You are looking for the disc set North American Navigator 2009. Make sure you do not purchase the NT version. I found the item on EBAY for $81and purchased it and it worked just fine. The 2009 is the last compatible map set that Garmin released for the 2620. Be certain that what you purchase includes that unlock key otherwise you will spend another $75 on that at the Garmin Unlock Site.
Here is the link that is good for a few more days, however, may relist it. The seller is yumelectronics and the search term is 2009 City Navigator.
This is the exact same setup im lookng at, just a different Yamahareceiver (RX-V663). Since the 3.5mm headphone jack and and the sub preout are both 'line level' you just need to pick up a male RCA to female 3.5mm jack converter from radioshack. I'd expect it to be around $5-8.
I have already stripped my old 5.1 HTIB system rca connector to use the surround speakers with my receiver. They work but are cheap speakers. Im tempted to do something similar with the z-2300 speakers, much higher quality, but I would definitely use a converter instead of stripping to keep them backwards compatible.
