20 Most Recent Recoton Advent Advent AW810 Main / Stereo Speaker Questions & Answers
Double check your connections at the transmitter. Swap inputs to see if the popping moves to the other speaker. Popping usually means blown, however......
Recoton Advent... | Answered on Dec 13, 2009
Turn your tv speakers off via setup.
You can't run both tv & audio out on any tv I have seen.
Recoton Advent... | Answered on Dec 08, 2008
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Recoton Advent... | Answered on Aug 26, 2011
First check whether the audio volume is not muted, and turn the volume all the way up, if you didn't already try that.
Did you try playing the system sounds? Enable them from the Control Panel (double click the sound and audio devices icon from the Control Panel), if you didn't try them, or if they aren't enabled. Then, play one of the system sounds from the "Sounds and Audio Devices" (second tab, labeled sound).
Can you see a speaker icon in your system tray? If yes, double click it. Do you get the 'Master Volume' control or do you get a message that says something like you don't have audio enabled?
If you get such a message, then the audio drivers are missing or corrupted, or not properly installed.
If you can open the Windows Device Manager, open it and check whether the sound drivers are present and are functioning correctly.
(For opening it in Windows 7, open the Control Panel from the Start Menu. Click on the System and Security link. In the System and Security window, click on the Device Manager link located under the System heading.  (Another easier way is to click the Start button and type the following command in the search box: devmgmt.msc Then, hit the enter key.
In Device Manager, expand the 'Sound, video and game controllers' (click the plus sign next to it). See that the sound driver is listed. Double click the item in that list that contains the word "audio device" in its name. Does Device Manager say that the device is working properly?
Instead of manually searching for the drivers, or your old drivers CD (you probably don't even remember where you kept it), you can download this driver scanning tool from here: http://xpdrivers.com/index.cfm or directly from this link: http://xpdrivers.com/download/download.cfm
After you download it, double-click it to install it and follow the simple instructions and run this tool to scan your system. It will inform you and update the needed sound drivers.
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit http://xpdrivers.com
Some FAQ about laptop sound and Windows 7: http://windows.microsoft.com/en-US/windows7/Sound-cards-frequently-asked-questions
Recoton Advent... | Answered on Mar 20, 2010
After connecting one, turn on the other. Then while both are powered on? Press and hold the button on both earbuds until they connect to one another.
Audio Players &... | Answered Yesterday
Free to anyone who can figure out how to block spam poster accounts.
First make sure that the contents are MP3, JPEG, or Windows Media Audio (WMA) format. Plug in the USB device. Next press the USB/Disc input button on the remote (top left below the power button) or press the Source button (left side to the right of the fast forward/next button) on the main unit of the HTS6510 repeatedly until you select this source. Use the Up/Down buttons on the remote to navigate through the folder. Press OK to play a file. To enter a folder, after navigating to the folder name, press OK to enter that folder. Press the Up button to return to a previous folder. I'm not sure if you can do this without a remote.
This is shown in the manual. Look at pages 9-10 for the buttons on the main unit and the remote. See page 34 to see the section on using a USB source. The support page for the HTS6510/05 is https://www.philips.co.uk/c-p/HTS6510_05/-/support . The current link to the manual is https://www.download.p4c.philips.com/files/h/hts6510_05/hts6510_05_dfu_eng.pdf .There is also the HTS 6510/12, https://www.philips.co.uk/c-p/HTS6510_12/-/support . The user manual is currently here: https://www.download.p4c.philips.com/files/h/hts6510_12/hts6510_12_dfu_eng.pdf .
I hope this helps.
Audio Players &... | Answered 2 days ago
Recoton Advent Advent AW810 Main / Stereo Speaker Logo
Popular Tags
5 questions posted
Top Recoton Advent Audio Players & Recorders Experts
Ron Rak
Ron Rak
steve-o steve-o
Level 1 Expert
Dayton Computer
Dayton Computer
Are you a Recoton Advent Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Recoton Advent Audio Players & Recorders
Most Popular Question
popping sound in rocoton advent wireless
  • Audio Players & Recorders
