First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, astuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
SOURCE: Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
