-   I have tried re chargeables and they dont even turn the camera on! They are the recommended power rating for a digital camera. I am reluctant to buy new ones until I know they will be powerful enough! What power rating would you recommend?? My current ones are 2000mAh. -   Gemface90
The D-535Z uses two AA batteries, and Olympus includes alkalines in the box. Unfortunately those won't last long and will end up in the trash. So I recommend buying a four pack of NiMH rechargeables (plus a charger), which gives you a set for the camera plus a spare. Unfortunately Olympus doesn't publish any battery life statistics for the D-535, so I can't give you any exact numbers.
It depends a lot on how much you use the flash and LCD screen. Don't leave the screen on all the time, use it sparingly and you should find an increase in shot numbers.
My c-370 was splashed with water and since then won't work. However when the power button is pressed...
(More)
My c-370 was splashed with water and since then won't work. However when the power button is pressed the red & green lights flash for a moment but that's the only sign of life. Is there any hope of repair?
i was at my olds house, and they brought out their old digital camera... i knocked it off the bench...
(More)
i was at my olds house, and they brought out their old digital camera... i knocked it off the bench and now the battery cover slide bit wont stay on/fixed down becuase two littel latch on the cover have snapped off.. im looking for a replacement cover.... any ideas....
Hi guys; I had a similar problem on mine C370 too. Today I had been using all day with full charge...
(More)
Hi guys; I had a similar problem on mine C370 too. Today I had been using all day with full charge on the batteries without any errors but late in the evening I suddenly found this nagging error message. As my friends here say, it might be due to low charge on the battery...lets hope as atleast I got something to try now. Thanks for sharing the important info buddy !!
