Hello, Linda -
There is a Facebook page (you will need to be a Facebook member), Vintage Mixers and More, where you may find the best advice:
https://www.facebook.com/Vintage-Mixers-and-more-681312818561039/
Have you called Sunbeam? if that does not work, go to Sherwin Williams. They have machine that can "duplicate colors" by that it can tell you what color it is and make it for you. p.s. you have to paint it or get someone to do it for you.
SOURCE: 2359, 2360 sunbeam mixmaster
It is the worm gears attached to the front of the motor in the housing I had the same problem on the heritage series. The parts are plastic so inevtiably they wear out.
SOURCE: Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
SOURCE: Sunbeam mixmaster jammed, will not
That picture looks like you are using the Heritage model, which is the one I just fixed for myself.
I had to remove two parts in order to get access to the piece that was causing the problem:
1) The "torpedo" shaped knob that sticks out from the mixer speed dial;
2) The speed dial itself
Both of these pieces clip-in, and can be removed with a screwdriver by pressing in on one of the hooks that hold them in place.
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; I tightened it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer I also noticed that the tilt release had become easier to use -- previously I found that I had to press the tilt release button very hard to get the tilt to unlock.
I hope this helps!
SOURCE: Sunbeam Heritage Mixmaster Won't Tilt
Hi
Most of them have a button to push that releases the mixer head to tip back. Sometimes the buttons stick and will not release. That picture looks like you are using the Heritage model.
You have to remove two parts in order to get access to the piece that was causing the problem:
After these two pieces are removed look for a small washer right below the motor (it is sitting on top of the upper portion of a screw) -- in my case this washer had come loose; tighten it with a 1/4 size wrench (you can also tighten it by hand to release the tilt, it will probably become loose in the future if you don't tighten it further, but if you don't have the necessary tools this will at least allow you to get your tilt unlocked).
On another note, after tightening this washer you may also notice that the tilt release had become easier to use -- previously you may have found that you have to press the tilt release button very hard to get the tilt to unlock.
Please do accept the solution and revert for further assistance.
Thanks
Rylee
SOURCE: After dough hooks for my sunbeam mixmaster model no. mx-ac
Use this link. I'd been looking for years and I found them here. http://buyitnow64.stores.yahoo.net/sustmidoho.html
